Old 10-07-2011, 01:17 AM   #1
NorthstarGMC
leaf spring upgrades?
I need to replace my leaf springs and also move a shock perch to accommodate the 9.5 GM 14 bolt 4.10 posi rear I just bought.
I've heard of running Jeep leafs, but has anyone done anything beefier? I'm afraid if I go with some Jeep leafs I'll have windup problems.
Suggestions and helpful information is appreciated. Thanks guys!
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 10-08-2011, 12:09 AM   #2
Captainfab
60-66 Nut
Re: leaf spring upgrades?
I would look into a set of later model GM truck springs. Either the 52" or 56" ones. I think if you go with anything other than original style springs, you may need to change the spring hangers on the frame. Not positive on that.
Old 10-09-2011, 03:03 AM   #3
NorthstarGMC
Can I bolt up later model springs on the original perches? If so what years? Is there a guide around for this? I've been looking and can't find much on the GMC leaf rear end upgrades. I can have custom springs cut but there are plenty of parts trucks around. Just want to see what has been working for others.
Old 10-10-2011, 12:02 AM   #4
Captainfab
60-66 Nut
If I remember correctly the '73 and newer springs are 2-1/2" wide and your original springs are 2 or 2-1/4" wide. So no the later model springs will not work with the original spring hangers. Plus I'mnot sure on the length of your original springs. Seems like they are shorter than 52"
Old 10-10-2011, 02:33 AM   #5
NorthstarGMC
I might as well chop the frame down to a short box and notch it at the same time. Sounds like this isn't a swap where I can just bolt up something. I'll be pushing 400hp and want something that will hold up. Thanks for the help. I'll look into it more.
