04-14-2003, 05:07 PM | #1 |
Painting Rear Wheelwells
My weekend driver is white, and I want to paint the rear wheel wells (underside). Should I go with gloss for easier cleanup, or semi-gloss? Any input would be greatly appreciated, because I don't want to do this too many times. TF
04-15-2003, 07:32 AM | #2 |
1969 Custom 30 wrecker
I would use GM chassis black if it were me but if you drive it alot, you will have to repaint occasionally as this area will take a beating.
You might also try POR-15 as I think they have a semi-gloss black now. That would hold up the best.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-15-2003, 02:42 PM | #3 |
POR 15 calls theirs "Chassis Black", also. Read the directions, I ruined a quart of expensive paint!
Silence is golden, duct tape is silver. - Scott |
04-15-2003, 10:23 PM | #4 |
SLOW BUT SURE,BUT CLOSER
Hey TF where you been, I use gloss black on mine and you can get by a couple of times a year. You goin' to the Nats next month at the Forge?
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
04-15-2003, 10:31 PM | #5 |
yeller
Black rubberized undercoating has always worked and looked well for me.
POR-15 can be tricky to apply..read the directions to a "T" if you want it to work correctly. -Jeff |
04-15-2003, 10:54 PM | #6 |
You could use Dupli-color truck bed coating. It rolls on and is tuff.
69 SWB LT1/4L60E www.classicplace.com |
