Old 10-07-2011, 02:17 PM   #1
CharlesUFarley
Questions about lowering a C-20
Hi all. I have a C-20 Suburban. At the moment it is static dropped with
2-1/2" spindles and stock front springs and 3" drop springs in the rear. I also have a set of 2" drop springs for the front and 5" for the rear, but I took them out because the front track width is so wide with the disc brakes that the tires rub quite a bit with the truck that low. I am running stock 8-lug steel wheels that I wouls like to keep. I might switch to air bags at some point for better ride, but don't intend to lay frame.
My questions are...
Is there a way to narrow the front end without chopping my control arms?
I saw in another thread that there are some CPP spindles that are narrower than stock? I got mine from Performance On Line.
Does CPP make Narrow spindles for the C-20.
These pics are with the 4-1/2" Front and 5" rear drop. I also have 1/2" blocks for the rear that I have yet to install.
I might be actually be willing to swap to drum brakes if necessary, but obviously would prefer to keep the disc brakes.
If control arms are cut, how bad is the effect on handling, turning, alignment, etc?
CharlesUFarley is offline   Reply With Quote
Old 10-07-2011, 04:03 PM   #2
SCOTI
SCOTI's Avatar
Re: Questions about lowering a C-20
CPP only makes the modular (narrow track width) spindle in a 1/2 ton version. You'll have to cut the arms, swap in an aftermarket x-member (Dropmember or similar), or maybe try different back-spacing for the wheels.
What size tires are you running?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-07-2011, 04:08 PM   #3
CharlesUFarley
They're on a 16-1/2" Wheel. The size on the tire is 8.75R16.5LT.
Old 10-07-2011, 04:13 PM   #4
CharlesUFarley
I have considered actually somehow moving the mounting points for the control arms inward on the frame to keep the control arm lengths the same. I haven't actually looked into it that far yet.This project is on the back burner for a while until I get another vehicle done. (A 65 Coupe De Ville). The caddy might lay frame, but the Burb will be more of a resto-mod. As I mentioned before, I want to keep the steel wheels. Just paint and detail the wheels or possible get a nice set of dog dishes.
Old 10-07-2011, 05:40 PM   #5
SCOTI
SCOTI's Avatar
While I understand liking the steel wheels & wanting to keep them, the 16.5's would have to go in my book strictly because they'll be your limiting factor. Your current 8.75 x 16.5's are about 29.5" tall.
Wheel Vintiques has 16" genie/solid steelies for 8-lug applications in 6-10" widths. A 16" wheel would allow for increased tire size selections & you could likely get varying offsets to help w/the track width dilemma.....
http://www.shopvintagewheels.com/16x...-bs/p/WV82003/
Food for thought.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-07-2011, 06:21 PM   #6
CharlesUFarley
Wow, that's great info. I actually looked on their web site and didn't see any 8 lug wheels....shows you how good I am at searching on the web....which explains why I asked a question that has PROBABLY been asked 72,000 times onthis forum....I did look though......briefly, lol.
Do you know if Wheel Vintiques would have those in 18" diameter...I have a set of brand new 18" tires that I was going to use on a set of 8 lug Weld whells that I have. Unfortunately the offset on the Welds is worse than my steelies for the front.
Old 10-07-2011, 06:23 PM   #7
CharlesUFarley
This is the Weld wheel I'm talking about. Not sure how well you can see the tire.
Old 10-07-2011, 06:25 PM   #8
CharlesUFarley
oh sXXt. I forgot that there is no tire on that wheel in this pic. It's just propped up in front of the stock wheel/tire.
Old 10-07-2011, 06:26 PM   #9
SCOTI
SCOTI's Avatar
As far as I know, they only offer the 16's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
