Old 10-07-2011, 03:49 PM   #1
gab50
front caster on solid axle
I was wondering if anyone has opinions or experience on caster in our trucks with solid front axle. I am not asking about model A's, fords or gassers but rather 47-59 trucks. I have used 1.5 and 6 and now have a set of 2.5 shims to try. I think the 6 was a bit much but it did steer straight. So much so that it didn't really like to turn easily. It did change the bump steer character which I think was due to making a bit of an S in the spring. Thanks
gab50 is offline   Reply With Quote
Old 10-08-2011, 02:46 PM   #2
Wrenchbender Ret
Re: front caster on solid axle
Generally about2-4 degrees works best.
Wrenchbender Ret is offline   Reply With Quote
Old 10-09-2011, 08:08 AM   #3
Knothead
Knothead's Avatar
I changed mine to 4 degrees,drives better, but with manual steering it's a little on the positive side. but the truck does go straight down the road!
Knothead is offline   Reply With Quote
Old 10-09-2011, 01:42 PM   #4
gab50
Thanks for the info. I will search out a set of 4's and give that a try. 3-4 was what I was thinking but it is always nice to talk to someone who has tried it.
