10-07-2011, 07:08 PM | #1 |
front hub assembly removal on 2000 ZR2
I need some ideas on an issue I am having with my 2000 Chevy S10 ZR2. I am replacing the upper and lower ball joints because they are bad. The upper ball joint went fine but now I am having issues with the lower ball joint. I have it all down to the hub assembly and have the bolts removed from it. Now I have pried on it for I don't know how long and it won't budge. Anybody have any ideas on what I can do to remove it. Any advice is greatly appreciated.
1948 Chevy 3600 http://67-72chevytrucks.com/vboard/s...d.php?t=417178 1981 Chevy C10 Longbed |
10-08-2011, 07:20 AM | #2 |
Re: front hub assembly removal on 2000 ZR2
big hammer we had to knock ours out on our 03 zr2, when you get it out get a wire brush and clean where it slides in
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-09-2011, 07:41 AM | #3 |
blood type; Retumbo
you don't have to remove it to do ball joints. just the axle nut and tap/tap the axle from hub while lifting knuckle assy. up at an angle from lower ball joint.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-10-2011, 10:10 PM | #4 |
I finally got the hub removed. It took a heavy hammer and some pb blaster to get it done. Then I switched to the other side and the hub pulled right out.
10-10-2011, 10:42 PM | #5 |
made in america
mine did that when i changed the spindles. on side was super easy. the other side took a sledge. why? to piss me off...
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
10-12-2011, 03:47 PM | #6 |
I think it is an S10 thing... they fight you every step of the way sometimes.
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
