Old 10-07-2011, 11:27 PM   #1
savatreatabvr
savatreatabvr's Avatar
Big Block Valve Adjustment: HOW?
I'm thinking my big block Chevy C20 needs the valves adjusted, I want to do them myself but I'm hesitant because I've only done small blocks before so I'll need some advice, any help is much appreciated!
savatreatabvr is offline   Reply With Quote
Old 10-08-2011, 12:11 AM   #2
67_SS396
Re: Big Block Valve Adjustment: HOW?
It's the same on a BB and SB and I'm assuming hydraulic lifters. I prefer the EOIC method. For me, it's the most accurate.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 10-08-2011, 12:13 AM   #3
rwhit57
rwhit57's Avatar
It's the same method. If you've done Hydr lifters on a SB and your BB is Hydr, just do it the same way.
rwhit57 is offline   Reply With Quote
Old 10-08-2011, 03:29 AM   #4
BigBlocksRule
Why do you think they need adjusted? Once is usually it for the life of the engine...
BigBlocksRule is offline   Reply With Quote
Old 10-08-2011, 12:04 PM   #5
savatreatabvr
I got the truck a month ago, it originally came with a SB and somewhere down the line somebody dropped a BB in it. I've had a BB before but this one just doesn't have the power it should, I've replaced the plugs, wires, rebuilt the Quadrajet and timed it but it still runs rough and hesitates taking off from a dead stop so my next guess was to adjust the valves. If that's not the problem then I will have at least eliminated the valves from the list of possible causes.
Old 10-08-2011, 04:29 PM   #6
savatreatabvr
Well, didn't adjust the valves but I did do a compression test, 6 cylinders had between 110lbs & 120lbs and the other 2 cylinders had around 90lbs. I know that's not good but would that small of an amount of compression loss make it idle rough and hesitate?
