![]() Join Date: Jun 2010
Opinion on repop doors
I am considering buying some new Tri-Plus doors locally. What do you guys think of them? I know there are horror stories of them not fitting well, but I also hear that Tri-Plus are better than most.
Any thoughts? Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Its a Truck Thing......
Re: Opinion on repop doors
I got an older repop Suburban door that was just junk, I wouldnt have passed it off to anyone like was done to me.....I hope that the fit and metal quality has gotten better but you wont know until you open the package....
I would look for original doors.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Wow. Maybe I should just fix what I have.
I bought 2 repop's from Classic ind. Dumbest thing I ever did. They don't fit right in any way. You'll see em on the parts board one day. Yes they'll be described that way.
Moderator
![]() Join Date: May 2007
A door has a lot of contours to it, making it very hard to reproduce accurately. I have NEVER heard a good thing about repop doors. I would try and locate a nice set of used originals.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Or just fix mine.
Moderator
I almost couldn't give away a set of not very bad doors about a year ago. Needless to say I was pretty thin when I was in sales.
I got a set of 71 doors from the local pick-n-pull that are rust free. One has a big dent and the other a bullet hole, but otherwise they're great. Used doors are out there, just troll the scrap yards and CL... |
Man of Mini-Talents
I used a Tri-plus door a it fit just fine. The factory doors have something like under oat sprayed inside so they are heavier and close better. If you get some repros, spray some on the inside and you'll be ok.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
![]() Join Date: Oct 2005
I tried to use some repops..they were not a good fit..they now hang out in the shed....
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
I know nothing about Tri Plus, but recently purchased doors from Atheys that were KeyParts and the fit was perfect, truck is in paint shop now and I myself would never deal with trying to repair old doors again. Maybe the two I have are the exception to the rule.
#12 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#13 |
I have Goodmark doors and they do not fit worth a darn. Course I guess it is possible that it was my bodywork on the cab but I dont think so.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#14 |
Got mine from Classic Ind. I had to cut (and reweld) the top of the outer window frame where the point is (front post and surround joint ) to provide the propper clearance around door opening, plus the body lines were out of alignment.
The door skin flexes like crazy ( oil cans, I think is the propper term ) It makes it very difficult to block sand because the surface is constantly moving. I had to re-enforce the inner surface to stop the flexing. The door skin is NOT spot welded to the inner door shell, so I had to provide them so that I could then pull the outer skin into alignment with the cabs lines (hard to explain) In other words a major P.I.T.A. |
#15 |
Anybody used TABCO?
#16 |
VA72C10
![]() Join Date: Mar 2008
Keyparts and triplus were the same. I just talked to Tim Christian about doors and he said Keyparts had worked on them and they are really good now. Keep in mind that every truck can be slightly different. I've used original doors that didn't fit one cab as good as another....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#17 |
![]() Join Date: Dec 1999
You must buy the doors labeled Key Parts not Tri-Plus they way more than the Tri-Plus and fit 100 times better!
#18 | |
#19 |
where do you get the tri-plus doors?
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
#20 |
Yea, poor fitting aftermarket panels are why its taking me so long. I tried to fix the factory doors, but had the same problems with the door skins flexing, plus somebody didn't think to mount the doors on the cab before he welded in the door bottoms. (ain't mentioning no names)
#21 |
I don't know about tri-plus, everyone else SUCKS!!!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#22 |
#23 |
Another bad experience here. I bought two new repops. One didn't even fit in the hole. After a week of trying to make them work they got tossed and replaced with originals that needed work. They fit like a glove.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
#24 |
They are actually three companys that make these doors. Yes three set of tooling out in the aftermarket world.
#25 | |
try finding them up here that are not rotted all the way up to the upper hinge |
