Old 10-08-2011, 11:15 AM   #1
lpguy
lpguy's Avatar
Rebuild or buy new?
I took apart the calipers on s10 frame today and planned on rebuilding them.but the bore has a some corrosion/pitting in it.. Should I just knock down the highs and install new piston and o rings or just buy new calipers? Ive never rebuilt calipers so im not sure whats useable or what should just be let go..fo
lpguy is offline   Reply With Quote
Old 10-08-2011, 11:59 AM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Rebuild or buy new?
Just my $.02 but I think those are trashed.
First above ALL things is "If you can't stop, you should not go"
Dan in Pasadena is offline   Reply With Quote
Old 10-08-2011, 12:03 PM   #3
Thadious
I don't know about the prices where you live, but up here in Canada, I picked up a new pair of calipers from Lordco for $21 each... a no brainer IMO!
Again... just my 2 cents... and you get what you pay for!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 10-08-2011, 12:25 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Rebuilt calipers are about $10 each with a lifetime warranty. The kit to rebuild them is $8.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-08-2011, 12:29 PM   #5
scooterskoolkustoms
scooterskoolkustoms's Avatar
go new
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 10-08-2011, 12:45 PM   #6
lpguy
lpguy's Avatar
Probably shoulda checked prices before asking... Yah 20-30 new is a no brainer
Old 10-08-2011, 05:55 PM   #7
bretcopsey
Pretty sure those would need to be sleeved to function properly, and that is reserved for "rare" items such as numbers matching restorations...
X5
New/re-manufactured
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 10-08-2011, 06:13 PM   #8
whid
brakes arent a place to cheap out........whid
whid is offline   Reply With Quote
Old 10-08-2011, 10:52 PM   #9
Coupeguy2001
Coupeguy2001's Avatar
Autozone offers metric GM calipers for $9.95 each rebuilt exchange. the rebuild kits are $6.95.
It doesn't make sense to use questionable materials when the economics and safety are in plain sight.
When I bought my frame stub, the thing had sat for about 10 years in the open. I didn't even take the pistons out, I clipped the brake lines, undid the bolts and trotted down to Autozone, and was pleasantly surprised.
Note:
I am still building my truck at this time, and haven't put any fluid to them yet. Stay tuned.....
Coupeguy2001 is offline   Reply With Quote
Old 10-08-2011, 11:11 PM   #10
hb32
hb32's Avatar
Whats your time worth?
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 10-09-2011, 12:59 PM   #11
Speedbumpauto
Speedbumpauto's Avatar
All good reasons to consider buying rebuilts instead of rebuilding but....the question was the pitting and it doesn't matter. The caliper piston never touches the bore. It rides on the square sealing ring installed in the housing. The caliper piston condition is much more important as it has to slide through the square sealing ring without leaking or binding. Those calipers are infinitely rebuildable as far as caliper housing condition is concerned. An advantage to doing your own is you can do some fancy powder coat to the calipers before you assemble them and then they'll look cool inside your fancy wheels. I use the Eastwood system and, even though it's a little compulsive/obsessive, I LIKE it.
Speedbumpauto is offline   Reply With Quote
Old 10-09-2011, 01:34 PM   #12
lpguy
lpguy's Avatar
I decided to just buy the reman with lifetime warranty, thanks for the info on the bore though thats what i assumed... I would powdercoat them but im gonna end up with smoothie wheels so powdercoated calipers would be a waste...
