Old 10-08-2011, 12:00 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Front Fender Breaces
Are the fender braces on the front fenders necessary?
Laid_Out_50 is offline   Reply With Quote
Old 10-08-2011, 06:40 PM   #2
bamabob
bamabob's Avatar
Re: Front Fender Breaces
I think they at minimum keep the fenders more rigid keeping them from sagging and flopping aound. And doubt Chevy would have gone through the expense of using them if they weren't needed. Do you not have them or are they in the way?
bamabob is offline   Reply With Quote
Old 10-08-2011, 06:46 PM   #3
Laid_Out_50
They're in the way and don't allow my truck to go down all the way when u release the air from the bags
Old 10-08-2011, 06:59 PM   #4
bamabob
bamabob's Avatar
I had to repair some fatigue cracks on my fenders so figured that there was a good bit of movement that they were restricting over the years. But then these were work trucks and most did not have an easy life. Try it without them and if you've got movement may be able to find another way to brace them.
How close are the running boards to hitting the ground now at full drop?
Old 10-08-2011, 10:49 PM   #5
Laid_Out_50
The front running board brackets are on the ground and the rears are about an inch
Old 10-10-2011, 04:13 PM   #6
texas56
texas56's Avatar
I didnt have them on mine for the last several months mainly because I couldnt find them lol but I just found them and stuck them on.
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 11-29-2011, 09:29 PM   #7
Laid_Out_50
Hey Texas, do the braces not rest on top of you tires?
Old 11-29-2011, 11:37 PM   #8
youngrodder
youngrodder's Avatar
Im not running any. I noticed some slight movement (shaking) of the front fenders down by the bumper. I plan to make some bracing under the front of the fenders to tie iunto the frame in order to stablize the fenders better. I too am on bags with 20"s and decent size tires, so I would not be able to use them either......
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
