Old 10-08-2011, 06:48 PM   #1
bamabob
bamabob's Avatar
Cab Mount Question
Anybody know why Chevy used the "shackle" type cab mounts for the year mounts on the 47-54 truck cabs? I would think that more rigid mounts like the front ones would best best all the way around. Figured there must be a good reason but I can't figure it out.
bamabob is offline   Reply With Quote
Old 10-08-2011, 07:57 PM   #2
coralhead
coralhead's Avatar
Re: Cab Mount Question
They act somewhat of a suspension for the cab and allow some up and down movement on uneven terrain when the frame flexes.
coralhead is offline   Reply With Quote
Old 10-08-2011, 08:45 PM   #3
mknittle
mknittle's Avatar
47-48 didn't use shackles, they a single cab mount in the center rear of the cab.
mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-08-2011, 10:49 PM   #4
MrTucker
MrTucker's Avatar
They were used to compensate for frame flex. If you rigid mount the cab in the rear corners, you'll lose frame flexibility, which isn't a big deal on the street.
More importantly - why doesn't anyone make these? I need a set, and they're next to impossible to find.
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 10-14-2011, 08:33 AM   #5
bamabob
bamabob's Avatar
Makes sense on the frame flex. I bought my 49 without a frame and put it on a 1995 Explorer frame which is very rigid. I forgot how light and flexible the original frames are. I started to mount it solid on all 4 corners but just having to drill a couple holes for the shackles made it too easy of a decision to stay with stock mounts.
