Old 10-09-2011, 10:27 AM   #1
Greshampiglet
Wireing Connector
Hey everyone;
I built my own dash cluster, I'm looking for some kind of wireing plug Male and female maybe 7 wires, so if need be I can remove the cluster without having to cut wires or rewire the whole thing got any suggestions?
GreshamP1GLET
Greshampiglet is offline   Reply With Quote
Old 10-09-2011, 10:31 AM   #2
lucifer
lucifer's Avatar
Re: Wireing Connector
i used a couple of weatherpack connectors. They are relatively inexpensive and easy to use. I think I used 2 4 wire connectors.
regards
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 10-09-2011, 11:58 AM   #3
Greshampiglet
You know thats what I was looking at, I was just wondering if anybody had found or knows of maybe a 7 or 8 pin plug,
GreshamP1GLET
Old 10-09-2011, 12:21 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I had some random trailer connectors in the "parts pile" in my garage. there were 4, 5,7 and 8 pin connectors. Something like that might work
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-09-2011, 12:56 PM   #5
mbgmike
we sell a kit from Ron Francis just for that. but here are some links to other companies
Mopar: http://dto.vftis.com/mopar/platform_select.asp [vftis.com]
ACDelco pigtails: http://www.acdelcotechconnect.com/pi/wiring-connec... [acdelcotechconnect.com]
Motorcraft pigtails: http://www.fordtechservice.dealerconnection.com/Re... [dealerconnection.com]
Nissan terminals/connectors: http://tools.nissantechmate.com/pdf/J-48817_HRK.pd... [nissantechmate.com]
Terminal Supply Co. http://terminalsupplyco.com/catalog/TSCfullcatalog... [terminalsupplyco.com]
Mouser Electronics automotive terminals: http://www.mouser.com/search/Refine.aspx?N=2355233 [mouser.com]
Waytek, Inc: http://order.waytekwire.com/scategory2/M37/320/550... [waytekwire.com]
Ballenger Motorsports: http://www.bmotorsports.com/shop/index.php/cPath/1... [bmotorsports.com]
White Products terminals/connectors/tools: http://whiteproducts.com/index.shtml [whiteproducts.com]
Deutch IPD: http://www.deutschconnector.com/ [deutschconnector.com]
Delphi Global Connection Systems: http://delphi.com/pdf/contact/brochures/DCS_Global... [delphi.com]
FCI automotive connectors/terminals: http://portal.fciconnect.com/portal/page/portal/Fc... [fciconnect.com]
mbgmike is offline   Reply With Quote
Old 10-09-2011, 01:20 PM   #6
Greshampiglet
MBGMike;
Did you have a connector that you carry in mind
GreshamP1GLET
Old 10-09-2011, 01:48 PM   #7
losthope
losthope's Avatar
or you could use these bullet connectors on each wire and plug or unplug each wire ! they are sold at any local hardware store:
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 10-09-2011, 01:56 PM   #8
DPowers
DPowers's Avatar
why not use the original 1/2 moon connector?
DPowers is offline   Reply With Quote
Old 10-09-2011, 02:54 PM   #9
mbgmike
any of the delphi/packard connectors work. we sell this from Ron Francis for $40.00.
