Old 10-09-2011, 01:03 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Dually rearend identification.
What rear end would come in a 1985 2wd dually??? Its a Dana I would assume, but not sure. It has ten bolts on the diff cover. It also has a MR10 stamped on the axle tube. Looking to buy a lower numerical gear set for it.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 10-09-2011, 01:21 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Dually rearend identification.
I thought they were mostly dana 70`s? 3spd and 410 gears not working for ya?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-09-2011, 01:26 PM   #3
texassquarebodies
Truck Nut
I need to be sure what it is before I fork out cash for gears. Im looking at 3:54 gears right now. It came out of a 4 spd truck, but going behind an automatic. I would like to afford to drive it. I might swap in a 700R4 instead of gears or both.
Tony Kee
Texas Square Bodies
Old 10-09-2011, 05:44 PM   #4
79k30dually
"70" will be cast into the webbing, dodge ran 3.54's in their 70's. Not much gear for a real working truck, Ron.
79k30dually is offline   Reply With Quote
