Formerly yellow72custom
Fuel cell in toolbox?
I have been wanting to remove the in-cab gas tank from my truck for more room for speakers. Today i bought a plastic Delta toolbox that mounts on the bed floor of my truck, and sits below the bedrails. There is more than enough room on the inside for a plastic 16-gallon fuel cell from Jeg's. My question is, would it be safe to mount the fuel cell in the plastic tool box? I could bolt the cell directly through the box into the bed if needed. I have some concern about vapors building up in the box, so would several 1" diameter vent holes placed around the box vent it out OK?
I really don't want to mess with a blazer tank, due to having to somehow make a filler neck without cutting a hole in my bed floor. Thanks for any help ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Seeing that plastic gas cans should never be filled in a truck with a plastic bed liner due to static electric charge, I would say venting is the least of your problems.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Young Gun wth Fast Inline
I second that... good idea, but you would rather have a truck left after your first fill up
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Wouldn't bolting the cell to the bed floor help ground out the charge? I don't want to blow it up either
Got big-block?
![]() Join Date: Jul 2000
I just bought the aluminum 16 gallon streetrod fuel cell from Summit to mount in my bed. It's vented, has an extended fuel neck and a 90 ohm sending unit in place. Plan on bolting/strapping it to the driver's side of the wood bed near the cab, mount a cool "aircraft-style" flip-top filler cap to the bedside, then run a marine-type filler hose to the cap. Won't be visible because of my bedcover. Should work great. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
