10-09-2011, 01:39 PM | #1 |
Scored at the pick and pull today...
Well i got lucky and the first explorer i found was a 2000 eddie bauer edition. I started pulling it before the downpour but i ended up getting soaked anyways, but now i have an 8.8 rear end with 4.10 ratio, L/S, and discs... so ended up being a good day...
10-09-2011, 02:34 PM | #2 |
Re: Scored at the pick and pull today...
If you don't mind us asking, how much did that set you back?
Posted via Mobile Device |
10-09-2011, 03:55 PM | #3 |
ended up being around $200, i was able to retain all brake lines and emergency brake lines, and brakes appear to be good.. I just need to buy a fitting to adapt it to existing s10 brakes and figure out the emergency brake, other than that should be an easy swap onto the s10 frame
