Old 04-14-2003, 08:50 PM   #1
MSL
MSL's Avatar
Floor board.
Well i had a chance to pull up the old rubber mat and the lining under it whatever thats called. well anyways my door weatherstriping is gone so its leaking inside when it rains so i got all that out and man i was thinking this floorboard is going to be bad crossing my figers hoping its not and i pull it all up and sigh of relief its got some rust but nothing i cant fix. now i have to get to work and get that sealed and new striping on the door and new door strikers since they are worn out and readjust my door.
What do you all use to take it up and seal it.
MSL is offline   Reply With Quote
Old 04-15-2003, 01:28 PM   #2
BigRed
If you're talking about how to get all the crap off the floor, I would use a steel brush to get all the loose crap off and then use POR15 to seal. Since you have surface rust, it will adhere very well and seal great.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 04-15-2003, 06:05 PM   #3
MSL
MSL's Avatar
Ok where do i get that at por15? Ya i was thinking wire brush should do and a scraper.
Old 04-16-2003, 08:27 AM   #4
BigRed
The only place I've seen por 15 is online at www.por15.com
Scott Shelbourne
Old 04-16-2003, 03:42 PM   #5
MSL
MSL's Avatar
Looks like a heck of a deal only $15 bucks for the POR15 thats a good deal do you guys use the other products and steps they show on what to do. I need to do my cab floor board i do not want that to get any worse than what it is.
Old 04-16-2003, 05:16 PM   #6
bagged81
Signals in the bumper.
bagged81's Avatar
Great thread, I am getting ready to do the same thing to my truck.
The $15 Starter Kit will only cover a 12sqft area, is that enough?
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 04-16-2003, 06:58 PM   #7
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
I got a second can just in case I needed it when I got my starter kit. Its still too cold to do anything on the truck though.
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 04-17-2003, 03:08 AM   #8
MSL
MSL's Avatar
How much does the POR15 cost.?
Old 04-17-2003, 06:37 AM   #9
TX_Mudder
I called Resto-Motive Labs (makers of POR) a long time ago when I needed to do the floorboards and they said the starter kit would cover 12 sq ft and that is enough to do the floorboards in a standard cab pickup.
Not quite. It is almost enough, but it is too thin and you really need a second can of the paint itself.
I used the POR and love it. Just buy the starter kit and one extra small can. And remember the prep is the most important part. Follow the directions and it will never come off!
-- Mike
TX_Mudder is offline   Reply With Quote
Old 04-17-2003, 04:52 PM   #10
bagged81
bagged81's Avatar
Thank you. Thats what I was looking for.
Jeff C.
Old 04-18-2003, 08:28 AM   #11
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Por-15 by itself is the greatest. The only problem with it was that top color coats wouldn't stick to it. RestoMotive Labs recently added another product to their line to address that problem. Tie-Coat over the POR-15 allows you to use standard automotive paint over the POR-15.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
