Old 10-09-2011, 05:28 PM   #1
Robert Paul Thomas
1967 C-10 SWB LS-6 T-56
Boy did I screw up
Took the clutch/brake pedal assembly apart, and I messed up the sleeve that comes in from the passenger side and bolts to the housing. Does anyone have a sleeve available so I can get this thing going. Whats the easiest way to get this in, pressing it in?
Robert Paul Thomas is offline   Reply With Quote
Old 10-09-2011, 06:34 PM   #2
hugger6933
Re: Boy did I screw up
ugh, I think your in the wrong room. Does'nt that bushing just slide in?I don't think it is like a press fit or anything.
hugger6933 is offline   Reply With Quote
Old 10-09-2011, 07:44 PM   #3
crazy longhorn
Fabricate till you "puke"
2nd that, you shoudnt have to press that sleeve.....all of mine have slid right out , after removing the bolt....got some pics? OOPs, I maybe I missed something.... are you dealing with the nylon bushing? If so, just clean/lube & slip it together crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-09-2011, 09:18 PM   #4
Robert Paul Thomas
man I wish it was that simple. When I took off the clutch rod bracket, spread it, it came apart no problem, that came apart with no issues. I then unbolted the bolt on the pass/ right side and tried to drive out that portion, and it was siezed. So I ended up pressing it apart, and it doesn't look pretty!
Old 10-09-2011, 09:20 PM   #5
Robert Paul Thomas
What I am looking for is the 6 inch long main sleeve, that bolts to the main housing on the right side, the end is sort of tear dropped shaped, one bolt holding it on
Old 10-09-2011, 09:45 PM   #6
crazy longhorn
That part is the same in a stick shift, or auto truck...shouldnt be too hard to find crazyL
