Old 10-09-2011, 09:31 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
?Brakes?
Got a strange brake problem.I noticed over the last couple of drives that the truck was a bit soft on the brakes.Checked and fluid was good.Today I jacked it up and started looking for leaks.I didn't find any fluid but I did discover the rear brake hose was cut.Enough that I can flex it and see the inside of the tube.OK,so I go order a brake hose.Then I look and the MC is still full of fluid.Both chambers.I never liked the brake bias I got from the adj.prop valve that came with the brake kit and planned on changing it but now I know it's junk since no fluid seems to be getting thru.I opened it up and same thing.Now when I installed it and bled the brakes they bled fine.
Has anyone else ever experienced this problem?
I tried "Inline Tube" for brake lines.Ordered at Spring Charlotte,cancelled a couple weeks before Fall Charlotte.When they asked why I was cancelling I said check the dates.They never even offered to get them out right away.
So I need opinions on who to get new front brake lines and a fact prop Valve from.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
