Old 10-09-2011, 10:51 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Broken parts warning
This for those of you that have done the "flatten and flip" trick with the rear, lower shock brackets. I did the upper and lower deal (shock relocation). About 5000 miles since. Yesterday, a guy stopped and said something was hanging down under my truck. A quick look underneath revealed a broken lower rear shock mount (driver side). Managed to get about 10 mi. to a friend's shop with a lift and a welder. Stuck the bracket back together (some). Checked the pass. side and it was cracked, but not completely broken. Tacked it back up too. Got it home and removed both brackets. SEE FIRST PIC. Going to re-weld both and add some gussets. pics coming.
Also whipped out a SolidWorks model of a heavy duty bracket that can be made from 2 x 4 x 0.25 wall steel tubing. SECOND PIC. Going to send those out to the shop for quote.
TobyArnot is offline   Reply With Quote
Old 10-09-2011, 11:05 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Broken parts warning
eek not good thanks for sharing info
John
1999 Toyota Tacoma 4x4
Old 10-10-2011, 09:31 AM   #3
fishingjred73
fishingjred73's Avatar
Have you seen this kit NO LIMIT has come out with? http://67-72chevytrucks.com/vboard/s...d.php?t=477839
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 10-10-2011, 11:59 AM   #4
coop34
Fishing, I am looking hard at that kit. I just wish the price was a little better.
coop34 is offline   Reply With Quote
Old 10-10-2011, 02:01 PM   #5
stich626
ya me too.. I'd like to see a gusset on the lower for use of coilovers
and the upper in a u, around the shock through bolt..
we have pot holes up here..
stich626 is offline   Reply With Quote
Old 10-10-2011, 04:56 PM   #6
TobyArnot
TobyArnot's Avatar
Re: Broken parts warning- Update
FYI
As promised, I TIG'd the crack and fabbed some gussets. Going to reinstall later today.
Ron White:
That should shut her up
Also scored some new shock bolts with more shoulder.
Old 10-11-2011, 05:58 PM   #7
TobyArnot
TobyArnot's Avatar
Fixed that, Now this - Luv' my truck
Replaced the shock mounts. Works great. At lunch today, the speedo cable broke. - AIN"T THESE TRUCK FUN ? ? ?
Old 10-13-2011, 12:28 AM   #8
Bert W
Bert W's Avatar
Those pics look a lot better than the first ones. Yes, they are fun!
Bert W is offline   Reply With Quote
