10-10-2011, 12:20 AM | #1 |
Will 73-87 diffs fit?
Will 73-87 3/4 ton 4x4 diffs fit into a 1972 blazer without mods? What mods are required?
formerly cooter |
10-10-2011, 09:19 AM | #2 |
Re: Will 73-87 diffs fit?
Front will bolt in, rear will need spring perches and shock mounts moved.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-16-2011, 04:14 PM | #3 |
Future TOTM Winner
A 1 ton rear axle from the 80's models will bolt in as far as spring perch width goes (1 ton is narrower than a 3/4 ton). One thing to keep in mind when putting ANY 3/4 ton or 1 ton rear axle in your 1/2 ton is the axle tubes of the heavier axles will be of a larger diameter than your factory 12 bolt rear. This isn't the end of the world, but you will need to buy/build new spring plates and U bolts.
This is a great way to go.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
10-16-2011, 05:32 PM | #4 |
thanx for the help and info guys!
formerly cooter |
10-16-2011, 07:17 PM | #5 |
I actually need to rebuild my 72 rear. Im not sure anymore what it is. I know its stock. Should just need wheel bearings and prob the carrier and pinion. Any ideas or numbers?
