Old 10-10-2011, 01:09 AM   #1
mobileortho
mobileortho's Avatar
Replacement door latches
I really really like the Altman latches but didn't want to spend that much right now. I tried to order a stock replacement from Classic Parts but learned that they had stopped selling the 47-51 latch due to numerous problems they were having with it. (LMC has also discontinued this item as well) They said that only one company was manufacturing these and they won't carry it anymore unless they can find another viable source. I have been able to locate them on other sights but I'm leary. Does anyone know of another option (besides the bearclaw) that wont require much modification?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-10-2011, 01:22 PM   #2
del
Re: Replacement door latches
I didn't want to spend that much money on the altman latches, but it was worth it. All you need to do is a little cutting and it bolts right in. The only problem is you no longer can lock the doors from the inside.
del is offline   Reply With Quote
Old 10-10-2011, 01:52 PM   #3
mobileortho
How are you locking the drivers door?
Robert C.
1950 3600
Old 10-10-2011, 09:53 PM   #4
del
You lock it from the outside with the key.
Old 10-10-2011, 11:06 PM   #5
BlueJeep
BlueJeep's Avatar
Not on the drivers side you don't...unless you've done some extra cutting.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 10-11-2011, 08:40 AM   #6
mobileortho
So the kit has provisions for adding an outside lock for the driver side door?
Robert C.
1950 3600
Old 10-11-2011, 08:11 PM   #7
BlueJeep
BlueJeep's Avatar
I'm not sure I'd call it provisions...other than to say that if you cut a lock into the driver's door you would be able to hook it up like the passenger side is. I think I'm going the power lock route with mine, for keyless entry.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 10-12-2011, 09:42 AM   #8
mobileortho
So you're saying that if you cut a hole in the door, the drivers latch can accept the lock just like the passenger side, right?
Robert C.
1950 3600
Old 10-12-2011, 01:11 PM   #9
del
Take a look at the triquemfg website. That's where I got mine. Use your existing interior and exterior handles.
Old 10-12-2011, 07:17 PM   #10
mknittle
mknittle's Avatar
Do they work with the 47-51 door handles?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-12-2011, 08:55 PM   #11
BlueJeep
BlueJeep's Avatar
Yes
I got mine direct from them too.
Yes, I have the turn down handles on my 49. That's the primary reason I went with these, as I didn't want to switch to the pushbutton style and they had it figured out.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
