Old 10-10-2011, 12:00 PM   #1
dean jendro
Old and crusty
dean jendro's Avatar
Grill Support Panel Question
What are the differences in the grill support panels? The repop guys offer 4 different ones 1960 & 1961 same, 1962 different, 1963 different and 1964-1966 all the same. Pictures of the differences would be great. I couldn't find any info about these changes any where on the FAQ section. Thanks!!
dean jendro is offline   Reply With Quote
Old 10-10-2011, 12:27 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Grill Support Panel Question
It's the bolt pattern/locations for the different grill supports (1.266 group number) as well as the center of the headlights and number of headlights.
My personal favorite!
Old 10-10-2011, 01:31 PM   #3
dean jendro
Old and crusty
Thanks. Looks like 63 and up also have notches where the frame horns pass under. The earlier frames must be different?
Old 10-10-2011, 01:33 PM   #4
aerotruk63
aerotruk63's Avatar
Goes to show how observant I am! LOL
Can you use a Chevrolet 60-61 on GMC's as well?
Yes the frames were different.
60-62
63-66
Old 10-10-2011, 01:41 PM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
Ok Aero.. what does N.S.S. stand for???
I would think non supporting structure,but it is clearly a supporting structure.???
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-10-2011, 01:52 PM   #6
dean jendro
Old and crusty
The LOL is really on me. I bought the most cherry grill support that I'd ever seen this weekend. When I tried to mount it up something was interfering with the fit. I soon realized it was hitting the frame horns and when I compared it to my old, beater panel realized the opening was different. There actually is a small opening ahout 1/2 inch deep that is not very obvious in your parts book and the on on my 64 is wider and a lot deeper.
I am now trying to figure out if this panel I bought is off a 60/61 or a 62 so when I go to resell it I am accurate.
Old 10-10-2011, 02:01 PM   #7
aerotruk63
aerotruk63's Avatar
Let's try Not Sold Separately since it says it's part of another assembly? Would that make sense?
Old 10-10-2011, 02:02 PM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
Yes,That's certainly feasible Aero,that does make more sense.
LOL ....just when we thought they were all the same !!
T
member#7816
'61 GMC in progress
Old 10-10-2011, 02:03 PM   #9
aerotruk63
aerotruk63's Avatar
Does it have 2 or 4 recessed areas for headlight clearances?
Old 10-10-2011, 02:14 PM   #10
dean jendro
Old and crusty
It has two, so I guess that makes it a 1962. The recesses are a lot smaller than the 64-66 also.
Old 10-10-2011, 05:03 PM   #11
MisterC
MisterC's Avatar
Well it may be considered sacriledge, I'm considering swapping out my '66 grille for a '63. Like Aero, they are by far my favorite looking grill.
Is this a pretty straight forward swap?
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 10-10-2011, 05:57 PM   #12
aerotruk63
aerotruk63's Avatar
I would think it could come close since both grills have the headlights at the extreme outer edge unlike the 62 with the light moved inboard. A few mounting holes might line up and the others would have to be drilled. Do you have a 63 grill at the moment?
Old 10-10-2011, 11:10 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I have tried most of the grilles in most of the supports. for sure the top outer hole is in the same spot in all of them 60-66 chev & gmc.
depending on what you have all the others have to be drilled...
a quick way I found is to mount the grille with the 2 that work, then use a can of spray paint and blast the other locations, remove the grille, and then you should have nice round dots where the holes should be.
Old 10-10-2011, 11:51 PM   #14
MisterC
MisterC's Avatar
No I do not have the grill yet. I'm a bit hesitant to shop for one as I haven't decided for sure if I will make the switch.
Old 10-11-2011, 08:42 AM   #15
dean jendro
Old and crusty
Would it be feasable to open up the area at the frame horn on the '62' grill support or would it look hokey? In my opinion the opening is way too big on the 64-66 supports anyway. The only thing that would worry me would be the flanging required to make it look right.
Old 10-11-2011, 09:27 AM   #16
jonzcustomshop
1961 crewcab
just cut the ones out of your 63-6 support, and then narrow them when you weld them into the early support
Old 10-12-2011, 03:38 PM   #17
dean jendro
Old and crusty
Jon,
That's a reasonable idea. You do a lot of metal mods and this probably isn't much of a project for you. For me, it's a major deal. But I think I'll try it. Thanks,
Dean
Old 10-12-2011, 05:23 PM   #18
jonzcustomshop
1961 crewcab
you gotta dive in some time! haha
it shouldn't be too hard, I looked a couple of mine over, first cut the pieces off your 63-66, narrow them up to where you want, and then use them as a pattern to cut your 60-62 support. if you do a nice job cutting and preping you should be able to have a local welder/or body shop put them back together for you pretty reasonable.
