Old 10-10-2011, 02:10 PM   #1
red rumbler
red rumbler's Avatar
secondaries wont open
hey guys im running a mechanical linkage holley double pumper on the stroker and i discovered yesterday my secondaries arent opening? anyone have any ideas on how to fix this? thankyou
red rumbler is offline   Reply With Quote
Old 10-10-2011, 02:30 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: secondaries wont open
If it's mechanical it's probably linkage-related. Are you running the stock throttle cable for the Quadrajet? If so, move the throttle bracket back toward the firewall so the cable will pull the throttle arm back further. I'm guessing your gas pedal sits too low, too? It's a common problem on trucks with aftermarket carburetors.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-11-2011, 03:17 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
i had to run an aftermarket throttle cable since mine was to short
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-11-2011, 03:33 PM   #4
RUSHNBOBO
90
Do the secondaries open when you operate the primary throttle shaft manually with your hand ? ....smooth with no restrictions ? Look down into the carb with a flash light and make sure all the plates are pointing straight up (90 degrees) at WOT.
RUSHNBOBO is offline   Reply With Quote
