Old 10-10-2011, 05:47 PM   #1
kcsa75
kcsa75's Avatar
AC Control Not working
Now that the worst of the hot weather is behind us here in the Midwest, I've decided it's time to see if we can get the AC working.
The previous owner said the control in the dash quit working and somebody installed a jumper to turn the AC on and off. I would like to see if this can be fixed, but I don't really know where to start.
How does the heater/AC control work. What happens when you push the levers around that makes the heat/def/ac come on and off?
Thanks in advance.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-10-2011, 06:28 PM   #2
john
member #16
john's Avatar
Re: AC Control Not working
Does this help?
john is offline   Reply With Quote
Old 10-10-2011, 06:28 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: AC Control Not working
There is a push button connected to the bottom lever that when you select it all the way to the left it suppose to push the button in and the compressor turns on.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-10-2011, 07:51 PM   #4
JimKshortstep4x4
The electrical switch that turns the compressor on is attached to the diverter box and is activated by a lever via a cable. Here is a picture of the diverter box and other parts of the AC . The diverter box is the box hanging down with the push button switch attached to it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
