Old 10-10-2011, 05:57 PM   #1
rooster11
steering wheel assembly for 1971 Chev pickup.
I have a restored 1971 1/2 ton Cheyenne, 2wd, four speed on the floor , tilt steering. The guy who built the truck put a GRANT steering wheel in it. classicparts.com says there was a deluxe and a standard steering wheel available for these trucks. He sells a standard wheel, but no mounting kit and says no one makes them yet. so, is there two steering wheels that came on this truck, and does anyone know where to get a NOS or reproduction steering wheel, horn button and its mounting kit also ? LMC has NO tech support, and did not know anything about what they sell. classicparts.com was $75 cheaper on the steering wheel which is nice, but can't supply the mounting kit as mentioned. Who has what I need ?
rooster11 is offline   Reply With Quote
Old 10-10-2011, 09:24 PM   #2
hugger6933
Re: steering wheel assembly for 1971 Chev pickup.
If you buy a replacement type wheel for your truck the hub will be made into the wheel so no need for a "kit"
hugger6933 is offline   Reply With Quote
Old 10-10-2011, 09:55 PM   #3
rooster11
do you know if there was a standard and a deluxe steering wheel made in 1971 ?
Old 10-11-2011, 01:33 AM   #4
HeavyD
HeavyD's Avatar
To my knowledge there was just one type of wheel, the big bus sized 2 spoke.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 10-11-2011, 06:26 AM   #5
One one steering wheel ever came in the 69-72 and that was the pickup sized wheel. Buses and other medium duties used the 67/68 style in a slightly larger diameter.
Old 10-11-2011, 09:31 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
67/68 had a 3 spoke wheel
69 - 72 had a 2 spoke wheel.
Other than color, they were all the same, no options. The closest to an optional wheel was the 67/68 had a fancy horn button on the CST trucks.
Old 10-11-2011, 07:55 PM   #7
Mike C
Mike C's Avatar
If you have power steering, my personal preference is for a 67-69 Camaro Comfort Grip wheel. They are smaller than diameter than the truck wheel, and IMO, look better than the two bar wheel. Get one for a 67-68 car as the wheel adapter is closer to the truck column diameter than the 69 which is a little larger because of the steering lock mechanism.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
