Old 10-10-2011, 09:56 PM   #1
ChrisAunchman
73-87 control arms?
I am planning on what todo with the front suspension on my 65 Chevy C-10. I have access to a complete front end out of a 1978 C-10. I have a few questions though.
Can I use the the 78 control arms in place of the older control
arms? or Do I need to swap the engine crossmembers?
If I order a set of DJM tubular upper and lower control arms can I
use the '78 spindles for a disc brake options?
Thanks,
Chris
ChrisAunchman is offline   Reply With Quote
Old 10-10-2011, 11:28 PM   #2
k1rodeoboater
Re: 73-87 control arms?
In order of your questions...
yes
no, but you can if you want to
...don't know
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 10-11-2011, 12:01 AM   #3
Captainfab
60-66 Nut
Yes you can bolt the '78 control arms up to your '65 crossmember. However, on the lower control arms, I recommend drilling out the holes in your '65 crossmember so you can use the '78 U-bolts.
About the DJM control arms, I would say that depends on which ones you order. That would be something you need to ask either the dealer you are buying from or DJM directly.
Old 10-11-2011, 08:52 AM   #4
ChrisAunchman
The control arms I'm looking at from DJM cover from 65-70.
Would it be better to order the 73-87 control arms and use my '78 crossmember or reuse the 65 crossmember?
My goal would be to use a spindle that would allow me to easily install disc brakes and upgraded steering. I have been looking at the plates that allow you to install the 73-87 steering boxes.
This is why I'm thinking of reusing the older '78 spindles.
Old 10-11-2011, 12:49 PM   #5
k1rodeoboater
...is your engine still in the truck? Pulling the crossmemeber with the engine still in makes it a bit tougher. Doable but just a bit more work.
Old 10-11-2011, 01:15 PM   #6
ChrisAunchman
The frame is bare. This is pretty much a ground up build. I have alot of options here. Just trying to explore the best option. Especially since I have the whole front end and crossmember of a '78 C-10.
Reason why I'm asking is because I have seen people use a 73-87 crossmember in these trucks. Just not sure if there is an advantage or not. It seems to make more sense though togo after market with the control arms.
Old 10-11-2011, 01:33 PM   #7
jimmydean
jimmydean's Avatar
It's easier to drill out the u bolts and use the early crossmember than it is to drill out the frame to fit the later crossmember. Either way works, though.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-11-2011, 01:48 PM   #8
scotts62
One day...
scotts62's Avatar
I just drilled a couple more holes in the frame and used the whole cross member out of a '74, just seemed easier at the time than taking two apart to make one work.
Scott
93 crew cab build
Project 62
Old 10-11-2011, 02:25 PM   #9
ChrisAunchman
So what do you mean drill out the U-bolts? I'm assuming you are talking about the lower control arm u-bolts.
Drilling them out? Are you talking about opening the holes in the engine crossmember?
Also is there any issue/difference in the coil spring seats between the earlier & newer setup?
Old 10-11-2011, 04:30 PM   #10
SCOTI
SCOTI's Avatar
The earlier trucks w/drum brakes had a-arm u-bolts that were 1/2". The later model trucks w/disc brakes (post 72) were 9/16". Either u-bolt will retain the newer a-arms but the later ones are technically stronger.
Coil springs will interchange.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-11-2011, 04:34 PM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
I used the whole suspension from a 75 chevy truck. All bolted up to my 65 crossmember. I am going to go back and drill the holes for the bigger u bolts as I used the smaller ones from the 65. I used the center link and all. Including the springs.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-11-2011, 05:43 PM   #12
ChrisAunchman
Thanks, so I am thinking there is no advantage going with the 73-87 crossmemeber. I'll just make the holes bigger for the U-bolts.
Now I just have to determine if it is worth it to rebuild my '78 arms or go with tubular ones. I am thinking of going no more than 3" of drop in the front. Is it better to get the drop in the control arm? or Do drop spindles work just as well. I'm not to convinced on using drop coils. I have seen issues with alignments after that.
Old 10-11-2011, 06:17 PM   #13
SCOTI
SCOTI's Avatar
Definitely do spindles over dropped a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 06:30 PM   #14
ChrisAunchman
Really....LOL I was so set on the arms.....Are spindles better for alignment purposes? If that is the case it may be better to keep the stock '78 arms under there then. I have already sandblasted the old control arms.
Old 10-11-2011, 07:50 PM   #15
SCOTI
SCOTI's Avatar
Dropped a-arms make a bad situation worse.... The spring pocket will be low enough that you constantly have to worry about both the pockets & the bushing/shafts hitting mother earth vs. just the bushings.
And, the spindles provide drop w/o changing shock or suspension travel. Dropped a-arms are the same thing as a cut spring so both shock & suspension geometry/travel are affected.
The down side of spindles are typically more issues w/back spacing related rubbing @ the lower a-arm lip (especially w/3" spindles).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2011, 08:54 PM   #16
ChrisAunchman
WOW awesome information....I did notice on the how low the pocket was on the a-arms...I wonder how 2" drop spindles and 1" or 2" drop coils would work......
Old 10-11-2011, 09:59 PM   #17
SCOTI
SCOTI's Avatar
2.5" spindle & 2" coils work well. Very well....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-12-2011, 03:57 AM   #18
stsalvage
Scrapper 1
stsalvage's Avatar
one they most people over look on theses front ends is on your truck before you take it apart.Look at how many shims are keeping that front end straight I have a 1965 3/4 ton and i swapped out a 1972 3/4 ton had nothing but problems with alinement.Later i was told all i had to do was change ball joints and use the 1971--72 disc brake spindle.My truck before i touched it never was in the alinement shop not one time in 35 years and it was a trash truck and a junk hauling truck before i did the swap
stsalvage is offline   Reply With Quote
Old 10-12-2011, 07:18 AM   #19
ChrisAunchman
Good point. I ussually always keep the shims labeled in 4 bags. The '78 frame I was able todo this. The '65 frame I am getting it bare with no A-arms on it.
Old 10-12-2011, 10:25 AM   #20
Chevy Fleetside
I used drop spindles.
