10-10-2011, 10:32 PM | #1 |
(warning lots of questions) automatic to manual swap
Ive been wanting to convert my truck from a th350 to a manual shift since I got it but Im wondering what are all the parts needed? I plan on buying a used muncie 4 speed or possibly a 5 speed out of a 90's chevy truck. Could this job be done in a weekend by an average joe like me or is it a tough job that should be done by a professional? Also if I go with the 4 speed what muncie would be the best choice? Whats the differences between the M-20, m-21, m-22? This truck is daily driven on highways and backroads if that makes a difference.
Thanks.
Put that hammer down and give it hell! 69' custom/10 longbed. 1999 1500 4x4 5 speed |
10-10-2011, 10:40 PM | #2 |
People know me
Re: (warning lots of questions) automatic to manual swap
I have done the swap a couple times in 4wds, It is a very straight forward swap, Just make sure you have everything, Clutch pedals, linkage, correct flywheel for the motor you are running, clutch, pilot bushing, flywheel bolts, pressure plate bolts, I think you may need a tall transmission hump, and possibly a new driveline, if you go with a newer tranny since the length may be different.
The 5 speed out of a newer truck may need to have a hydraulic bellhousing which complicates things a little more. Both swaps I have done have been the sm465 and were both hydro clutches.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
10-10-2011, 11:08 PM | #3 |
The Older Generation
This should keep you busy for a while... http://67-72chevytrucks.com/vboard/s...d.php?t=417079 http://67-72chevytrucks.com/vboard/s...d.php?t=212959 http://67-72chevytrucks.com/vboard/s...d.php?t=438224 LockDoc
05-23-2012, 11:16 PM | #4 |
ok, im kinda bringing this thread back from the dead haha. Well ive still been wanting to do this swap just havent found the right donor truck until today. I was out at a salvage yard and back in the trees was a 68 lwb that hasnt had a part taken off it and had all the manual parts I would need, I think haha. the truck had a 350 and a 4 speed all still in the truck. the question is, would this 68 supply me with all the parts needed to swap a 4 speed into my 69'? I dont plan on using the granny low that is in this 68' but instead use in a muncie or t10. Also in the same yard I found another c10 with a set of buckets that I plan on picking up too if the price is right.
08-25-2012, 01:53 AM | #5 |
The 4 speed swap is pretty straight foward. That tranny is a heavy one however. Dont forget the 4 speed hump! Did you pick up the buckets?
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
08-25-2012, 07:11 AM | #6 |
Don't forget to list your automatic stuff for sale when you get-r-done
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
