![]() Join Date: Nov 2005
GMC 305 V6 complete w/3 speed, PO installed Power steering
For Sale: 1967 GMC V6 305 Just pulled today.
Engine turns over by hand had good coolant in it too. Sitting for seveal year so I dont know the actual condition and I never tried to crank it in the truck. Has Owner installed/fabraicated power steering. Three speed transmission shifted into all gears easialy. Air cleaner also included. Engine stands included but front motor mounts are broken. For Sale where it sits outside of College station TX. I will not ship and buyer must meet me there or pay for shipping for me to move it to the Austin TX area only. They can pick it up there. Photos below, please ask questions in the thread. $200.00 OBO Please note that engine, if not sold, will end up in a pile of parts going to the junkyard. Id really like a V6 guy to get this so please make an offer. Thanks, Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale |
Re: GMC 305 V6 complete w/3 speed, PO installed Power steering
Price Drop... I know, I know.. It has not even been 24 hours and I'm dropping the price...
175.00 OBO... It really is going to the scrap yard. I just got the deposit on teh four door truck so between now and thanksgiving I'm tossing whats left of the suburban and the white GMC This thing came from on the trailer along with a few F word engines and this one is going with it. Weight is weight to the scrapper. Surely someone in texas is a V6 guy and wants this GMC motor.
try putting this in the 66 board section will get more bits if you were closer to va i would take the motor
not a bad idea. Thanks,
![]() Join Date: May 2007
you could sell parts off of the engine and then take the rest to scrap and you would get more money out of it IMO the 66 section should be a better response .
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Vintage 4x4s
Interested in the oil pan if its not dented and you part it out.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#7 | |
Question though: I saw that your 351 V6 shows a turbo 400 transmission attached to it. Will autos directly bolt to this engine? If so that should mean the transmission would bolt to a V8 or I6 is that a correct statement? If so I can use the transmission myself. Another question: if I am just using it as a drive around putt putt type of truck is the V6 worth keeping? My plan is to use the clip and cab on a SWB frame with a step or fleet bed and install a I6 three speed manuel or turbo 350 that I ahve stashed away in the barn. Didnt intend to do anything with it other than have something to drive around make a trip or two to the home depot. I shyed away because ive heard they have no top end on them and unless I wanted to drive 55 MPH everywhere as pushing it could cause it to blow up.
not positive but pretty sure its got real good troque for putting around she should do it
#9 | |
Vintage 4x4s
The 400 should bolt up but you will need an adapter to run on the V6. I'm not sure on using your trans on a V8 but the guys in the 60 to 66 section would know or I can ask for you on the 6066 Gmc guy discussion forum.
sale and scrap both on hold. I need to do some more research on the engine.
Hello Round Rock-
There is a triangle-shaped adapter between my 305 V6 and the TH400... all stock original. Recently rebuilt the trans and found that all 3 corners of the plate were broken. But all the pieces were found, welded, and it's running fine seven months later. as a weekend truck for errands, it's no less useful than anything else. Being in a hurry will involve different gearing and taller tires... The conversations with onlookers are worth the effort. |
Not sure if I'm going to use the V6 right now, but I'm going to end up keeping it. I've got the room for storage and it will simply go in the barn. Right now i'm in the process of getting rid of the LWB frame and other parts and will get back into building something in the Spring.
#13 | |
jtsand |
#14 |
Interested in buying 305 V6 engine. Is it still available? How do i get ahold of you?
#15 |
![]() Join Date: Oct 2015
You do realize this post is from 2011 right?
