10-11-2011, 03:52 AM | #1 |
Just a Member
1966 Chevy 327 with top end rebuild
$1200PRICE IS NEGOTIABLE!!!! ALL ORIGINAL ERA correct besides top end performer intake of course.60 pass head 64cc and 69 head 64cc..Rare 1966 Chevy 327 top end rebuild. Top end rebuild consisting of umbrella seals and valve seals, push rods and valve job. 1.5 exh. 1.72 int. New pro comp hydraulic lifters, power washed and degrease intake valley, cylinder heads, and intake. New Edlebrock head gaskets, new Edlebrock intake manifold gaskets with Edlebrock Performer series 2101 intake. Chrome Edlebrock valve covers and Chrome Edlebrock air breather. Chrome tightening pegs with spark plug wire guide rails for very clean look. New spark plugs. Also dropped oil pan and power washed and acid bathed theinterior of oil pan making it like brand new. Painted Oil pan black with POR-15. Painted heads black as well with high-temp paint and baked on. Engine block power washed and heavily degrease then restored to original Chevy orange. ALL cylinders read strong 150 psi on compression test [COLOR="Red"]Block vin# VI228YH. Date casting L8 6. So if you had a 1967 Chevy built in Jan. or Feb. 1968 this could be the matching era correct engine to top off full end resto. Block casting# 3892657. Heads casting# 3774682. [/COLOR]Runs like brand new. Also have Holley 650 cfm carb would negotiate to go with. Long style water pump as well with flywheel. This also includes stock distributor with new rotor and new ignition module(have spare).
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 10-22-2011 at 01:56 PM. Reason: pics |
10-11-2011, 04:03 AM | #2 |
Just a Member
Re: 1966 Chevy 327 short block rebuild
wth... I'm going to sell it all!!!! lol
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
10-11-2011, 01:59 PM | #3 |
Just a Member
Ttm
10-11-2011, 07:11 PM | #4 |
GobbleStalker Calls
Dang shipping would kill me.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
10-11-2011, 07:28 PM | #5 |
Just a Member
ROAD TRIP!!! lol. I am a sucker to please.. .I have fam in Grand Rapids...my cousin Jason and his wife is from Canada.. .I just text him about how often they make it around Toronto... I will keep you posted.. .I REALLY dont want to see it go but I have two engines and only one truck now...soooooo Yeah
10-11-2011, 08:54 PM | #6 |
Just a Member
You are also the one that wanted hood hinges prepped as well correct?
10-12-2011, 02:02 PM | #7 |
Just a Member
ttt
10-12-2011, 05:44 PM | #8 |
GobbleStalker Calls
Yes thats me
10-12-2011, 05:48 PM | #9 |
Just a Member
10-13-2011, 02:49 AM | #10 |
Just a Member
ttt
10-14-2011, 01:53 AM | #11 |
Just a Member
HMMMM WTH??? I guess people are not fond of rare 327's.
10-14-2011, 03:44 PM | #12 |
Just a Member
ttt
10-21-2011, 02:56 AM | #13 |
Just a Member
ttt... this engine is solid No DOUBT about that... Make an offer... I know someone wants a matching genuine block for that coveted 67 GM truck of theirs... Lets do this!!!
10-21-2011, 04:40 AM | #14 |
Laid Back
The motor needs matching heads and it's not good to just pop the oil pan off and power wash the internals!!!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
10-21-2011, 06:11 AM | #15 |
What's rebuilt about this engine? I don't see anything about a rebuild or overhaul in your description. Are these rare? If so,just the short block since it has 350 heads,right?
10-21-2011, 06:51 AM | #16 | |
Laid Back
10-21-2011, 11:58 AM | #17 |
Just a Member
I did not power wash the internals... The oil pan was dropped to remove all old sludge deposits and you make it sound like I dropped it and power washed the combustion chambers or something... The heads were power washed and valves lapped and checked for seat. The push rods were replaced and the lifters... I used a dial indicator to check for spring wear and they were cleaned and reused.
As far as the heads go...yes they are not same year as block but that is still referring to era correct as in they were used on 327 blocks in the 60's,,,they are both 64 cc...so they run fine on the 327 and I may stand corrected but the 350 was not even an option in 1960 so how could it be a 350 head. Oh yeah also new spring retainers and yes I would consider that a short block rebuild just not... i have also done complete long block rebuilds with hot tanks... and magnaflux for cracks and such... Just in case a short block rebuild does not refer to "small block" it is a term used for top end rebuild... The long block rebuild is complete overhaul with reground crank, bore, rings...etc...etc.. I am sure everyone is aware of this though... I explained that the point of "era correct" was the significance of the block casting date,,the YH suffix on the vin which designates it as a truck motor. Which means from the casting date of L8 6..it was built In December of 1966 which would put it right in line for a 67 GM truck that had a production in Jan or Feb of 1967. Oh yeah also... When I washed the intake it the block was COMPLETELY sealed off from the moisture... Once again it is not like I took the heads off,,,the intake manifold...the oil pan...and strated spraying away... The engine ran fine from the get but rear seal on manifold had been leaking for quite some time when I got it so started with replacing that gasket and this is where I ended up... Hope I clarified a little.. Any more questions or constructive critic will be more than welcome. Thank you..
10-21-2011, 01:00 PM | #18 |
Laid Back
You need to check your numbers again on the heads
10-21-2011, 10:47 PM | #19 |
Just a Member
I was not even going to give myself the pleasure of knowing I am right but hey...you asked for it...And this goes out to anyone and including my opinion. When I "know" something to be true,,,I have seen it in a documentary...(scinece channel,discovery, speed, overhaulin',rides, GM EMPLOYEES etc.. This goes for everything and all knowledge I surprisingly "claim" to have. I am very opinionated myself,, but when I state and opinion (how I feel or think about something) I always clarify by stating" in my opinion...or I think" so the two don't get mixed up... So with all that aside and opinions put in proper order here ae the facts....just as I already stated...I did this about a year ago...by doing research...which solidifies my claim as facts...
Link 1....http://www.chevy-camaro.com/chevy-ca...es.asp?group=5 Link 2...http://www.nastyz28.com/sbchevy/sbch.php
10-21-2011, 10:48 PM | #20 |
Just a Member
and a little more "facts"
10-21-2011, 11:06 PM | #21 |
Laid Back
So you are saying those heads are a matched pair?
10-21-2011, 11:20 PM | #22 |
Just a Member
Never said that bub...Refer to the description at beginning of post... It is all in black and white... Obviously you don't want it so please find someone else to educate... i know what I am doing...
Thanks, Duane
10-22-2011, 08:22 AM | #23 |
Duane,I'm not trying to make a stink,but I feel the integrity of this parts sale section relies on honest and accurate information. I said 350 heads because the left one has the alternator mounting boss. So ok,it could be a 1969 327 head. But,not a '67 truck,like the block. You never gave that casting number before my comment,but the head numbers still do not "match" the block,nor each other. I guess what you meant by "ALL ORIGINAL" was that it is all GM castings?
You are wrong about your definition of what "short block rebuild" is. A short block rebuild means the block assembly minus the heads. With the heads is a long block. The cam/bearings,lifters,push rods,valve guides,valve seals,and checking valves,valve springs,retainers is a top end rebuild. If just the heads are done then it's a head job. If new pistons aren't used on a short or long block job then it's an overhaul. I just don't see where anything is "rebuilt". I'm not trying to mess your sale up. But,I think we all deserve an accurate description. You are fairly new here and I just feel,as a member who's been around a while,I'd help you mellow into place here with letting you know how we like to deal on this site. This place is like a tight knit community where we all like to help one another out,that's all.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-22-2011 at 09:31 AM. |
10-22-2011, 10:19 AM | #24 |
Laid Back
Well if you wanna read what's in the black and white, your very first post says you pulled the pan and, acid and power washed the interior of the motor.... Then you come back and say you didn't pull the pan and power wash it!!!!! So guess what buddy I don't believe one word about anything you say..... Good luck with your sale$!!!!!!
10-22-2011, 12:33 PM | #25 |
I believe he meant the inside of the oil pan. and i don't think there is a reason for anyone to get to worked up about this add ( mind you I often forget how perfect everyone is) people make mistakes and people interperate things differently.
good luck with the sale. |
