Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-11-2011, 07:01 AM   #1
BigDan3131
BigDan3131's Avatar
Question Is my thinking correct?
So a torque convertor multiplies the power an engine makes what if you had one with just say 1000hp and 800lb/ft ft/lbs of torque. Then instead of a normal torque convertor you used one of the hollow ones that drives your pump could you save the shock to your transmission or put a better way would it be able to handle more power or less power than with a torque convertor? I'm just curious because even though it works in boats with that BLANK Drive they use with TH400's could it work in a vehicle?
Blank* I forgot the name of that type of drive.
BigDan3131 is offline   Reply With Quote
