Old 10-11-2011, 12:28 PM   #1
dukcaln
dukcaln's Avatar
carb adjust & timing, what order
Ok, finally got access to a vacuum gauge and will be adjusting the carb and timing again since I fixed my header leak and vacuum leaks! So my questions are the following:
1) What order first, timing or carb?
2) Using the vacuum gauge where do I want to see the vacuum at, highest possible right? Once I reach that making adjustments on the screws do you have to back off and turns before setting it?
3) Were are most of you setting your idle at and is the idle setting the last thing?
4) If I missed anything on the vacuum gauge process, a step or how to please advise.
Hoping to start doing this in a couple hours. Thanks all
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 10-11-2011, 12:36 PM   #2
webfoot
Re: carb adjust & timing, what order
1. Adjust the timing first.
2. correct. 1.5 turns out is good for starters, test and adjust via vacuum readings from there.
3. Depends on your camshaft specs. yes.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-11-2011, 01:08 PM   #3
57larry
X's 2
57larry is offline   Reply With Quote
Old 10-11-2011, 01:17 PM   #4
longbed67
longbed67's Avatar
x 3
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-11-2011, 01:28 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
x4
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-11-2011, 01:40 PM   #6
dukcaln
dukcaln's Avatar
thanks all so my only not so sure is this...once we are adjusting the screws on the carb to get the highest vacuum and reach it, we back the screws in 1.5 turns and leave it? What is the average vacuum for a high we can expect?
SOLD 1972 chevy c10
Old 10-11-2011, 01:45 PM   #7
webfoot
No, for starters turn the screws all the way in (not too tight!) and then back out 1.5 turns. That usually gets you close, then leave wherever you get max vacuum reading. Vacuum will depend on your cam which you have not provided specs for.
-me
Old 10-11-2011, 06:20 PM   #8
dukcaln
dukcaln's Avatar
all went fairly well except I had some issues with the needles.... will post in another thread
SOLD 1972 chevy c10
