Old 10-11-2011, 02:02 PM   #1
jdheff1982
Oil Pressure gauge.
Hello,
A few weeks ago I had to replace the nylon oil pressure line because it developed a bad leak. I bought an Autometer brass line to use instead. When I installed the brass line, it had tapered balls with a hole on either end. One end of the tubing was fairly easy to thread thru the "ball", the other end I had to sand to get the ball to stick to the end of the line.
Today, I found an oil spot underneath my Sunpro oil gauge. This is the same end that I had to sand and was not able to get the ball completely on.
My question is this, do those balls collapse after initial use to provide a seal? I haven't pulled the line off to see the condition of it. My guess is the ball did not seal proper and allowing oil to blow by.
Thanks.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 10-11-2011, 02:58 PM   #2
TJBrown
TJBrown's Avatar
Re: Oil Pressure gauge.
may have gotten a little rough area under the compression ball whick could cause a little leak. I usually cut a little long and put the ball on and cut to length. Makes for a good connection that way.
85 Silverado SWB
TJBrown is offline   Reply With Quote
