Old 10-11-2011, 03:56 PM   #1
neslie
tire size
I lowered my 66 fleetside 4.5 in front and 5 in back. I have 15x8 truck ralleys with 255/70r15 tires and I can't get the rear wheels on with the suspension relaxed. Do I need a different tire and if so what size? Or is there a trick to getting them in?
neslie is offline   Reply With Quote
Old 10-11-2011, 04:13 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: tire size
you got it jacked up with the rear end or frame?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-11-2011, 04:26 PM   #3
neslie
Re: tire size
I had jack stands under the frame with nothing under the rear end.
Old 10-11-2011, 04:29 PM   #4
blackedoutharley
Re: tire size
I think you're going to find that a nearly 30" tall tire is too much for that much of a drop.
blackedoutharley is offline   Reply With Quote
Old 10-11-2011, 04:51 PM   #5
neslie
Re: tire size
That's what I figured. Any idea on what size tire I would need?
Old 10-11-2011, 05:05 PM   #6
forestb
forestb's Avatar
Re: tire size
Before you go and get smaller tiers. What I do is jack up only the side of the frame that you want the tire on. This will cause the opposite side tire to take a lot more weight and bring the side you want to put the tire on down a lot further out of the wheel well. If both tiers are off you will need to get a tire that is easy to put on, on the truck first. I would make sure that you have the front tiers on first so that the front of the truck doesn't fall off the jack stands.
forestb is offline   Reply With Quote
Old 10-11-2011, 06:15 PM   #7
gimmy 64
Re: tire size
i have 275-60- 15's on mine what i did was to jack up rear end so tire is off ground. put jackstands under then jack up the frame. PITA
gimmy 64 is offline   Reply With Quote
Old 10-11-2011, 07:44 PM   #8
neslie
Re: tire size
Any problem with rubbing gimmy 64?
