Old 10-11-2011, 05:39 PM   #1
72gmcshorty
72gmcshorty's Avatar
Are these connectors ok?
I went to my local j/y looking for a complete fuel line from tank to motor. I was not able to find a setup that used the corvette style regulator. I did find the other setup (i think).
Looking at the fuel tanks i noticed that gm didn't use any metal connectors or fancy braided hoses. I grabbed a couple of these and was wondering if these connectors would work from the fuel pump to the regulator?
If they could be used, how do you shape the tubing?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-12-2011, 08:46 AM   #2
Shon
Re: Are these connectors ok?
I am using those from Dorman on my 88 and reused some of the Ford locks like that.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-12-2011, 09:24 AM   #3
mbgmike
good links for connectors courtesy of AITN
Here are a bunch of links, most of which have been posted
here before:
Mopar: http://dto.vftis.com/mopar/platform_select.asp [vftis.com]
ACDelco pigtails: http://www.acdelcotechconnect.com/pi/wiring-connectors/ [acdelcotechconnect.com]
Motorcraft pigtails: http://www.fordtechservice.dealercon...torcatalog.pdf [dealerconnection.com]
Nissan terminals/connectors: http://tools.nissantechmate.com/pdf/J-48817_HRK.pdf [nissantechmate.com]
Terminal Supply Co. http://terminalsupplyco.com/catalog/TSCfullcatalog.pdf [terminalsupplyco.com]
Mouser Electronics automotive terminals: http://www.mouser.com/search/Refine.aspx?N=2355233 [mouser.com]
Waytek, Inc: http://order.waytekwire.com/scategor...%20Connectors/ [waytekwire.com]
Ballenger Motorsports: http://www.bmotorsports.com/shop/index.php/cPath/109 [bmotorsports.com]
White Products terminals/connectors/tools: http://whiteproducts.com/index.shtml
[whiteproducts.com]
Deutch IPD: http://www.deutschconnector.com/ [deutschconnector.com]
Delphi Global Connection Systems: http://delphi.com/pdf/contact/brochu...balCatalog.pdf [delphi.com]
FCI automotive connectors/terminals: http://portal.fciconnect.com/portal/page/portal/Fc... [fciconnect.com]
mbgmike is offline   Reply With Quote
Old 10-12-2011, 12:26 PM   #4
72gmcshorty
Is there a connector (that i can find in the local auto parts store), that will allow me to connect rubber hose to this sending unit?
1992 Gmc 2wd
