Old 10-11-2011, 09:39 PM   #1
turner16
OMG does everything happen in 3's!
So I had this rad leak, easy fix it was just the cap. However, when I was laying around looking at the truck (71 fleet) I found my tranny was leaking from the front and my rear seal is leaking at the left rear wheel. Does everything happen in 3's? I'm really pissed about the tranny because I paid a shop $400.00 to go through it and replace all the seals and gaskets! Now only a year later its leaking again? Should I go back to the tranny guy?
Also have a vacuum leak that I can't find! Any advice on that one!
turner16 is offline   Reply With Quote
Old 10-12-2011, 07:41 AM   #2
OARNGESI
OARNGESI's Avatar
Re: OMG does everything happen in 3's!
Id go back of course it may be out of warranty if its been over a year
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-12-2011, 08:47 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Try the tranny guy.The worst that can happen is he says(NO) it's out of warranty.The vac leak should be an easy find.Just take a can of carb spray or WD and spray the areas where it may be leaking.You'll hear a change in the sound.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-12-2011, 09:09 AM   #4
Fantom
Fantom's Avatar
If it's an A/C equipped truck, check for vacuum leaks on the vacuum tank that's mounted to the evaporator core housing. (near the firewall). My truck had a vacuum leak there. It took me forever to find it.
Fantom is offline   Reply With Quote
