Old 10-11-2011, 10:30 PM   #1
72gmcshorty
72gmcshorty's Avatar
Transmission mount and LS motor...
What did you 2wd guys end up doing to make a 4l60e work with the factory trans crossmember?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-12-2011, 09:28 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Transmission mount and LS motor...
I drilled some holes in the frame and slid the crossmember where it needed to be. I'm running swap headers so I had to change trans linkage to something more standard.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-12-2011, 10:53 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Same here, I'm even using a $6.50 TH350 trans mount.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-12-2011, 11:57 AM   #4
72gmcshorty
did you guys have to raise the tran mount up at all?
1992 Gmc 2wd
Old 10-12-2011, 02:01 PM   #5
brad_man_72
the boat guy
nope. Ls setup, unknown factory stands, possibly swapped from l to r, sbc mounts, s&p plates. Pass side coil less than an inch from firewall.
