Old 10-12-2011, 12:11 PM   #1
El Campo
El Campo's Avatar
Cut front springs or lower front body mounts??
My project Attempt/Mistake #2 is sitting higher in the front then in the back and I hate that look. Already have a 6 inch drop in the back from Classic Industries and have 3 inch drop spindles in the front and one inch big block drop springs. At least that is what I was told when I bought everything but now the front is too high. As posted in my build thread I dropped the engine down and moved it back and so I am having interference with my steering linkage and radiator shroud also. Shall I Z the frame in front of the motor and thereby drop the front body mounts, fixing my higher front end and my shroud problem, or just cut the springs down a bit and figure out some other solution for my other problems. I know that if I drop the front body mounts that I will have to alter all my others but I have already done that once before. Would I have any unforseen problems by essentially having the body sit on the frame slightly lower in the front then in the back?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 10-12-2011, 12:24 PM   #2
eurospec1
eurospec1's Avatar
Re: Cut front springs or lower front body mounts??
The front end is bolted to the cab..You cant just "lower the body mounts" in the front, it will all hang on the cab, if you dropped the whole cab then it would not line up with the bed...Much better to adjust ride height with the springs.
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 10-12-2011, 12:49 PM   #3
El Campo
El Campo's Avatar
I am aware of that and that was one of my concerns. I was thinking that I would have to mess with the bed mounts too which I know there is not much adjustment there. I was thinking that I may have to cut some of the bed sills in order for all the body lines to line up the way I wanted. Doesn't your ride go all to Hell when you cut springs?
Hook em Horns!!!
Old 10-12-2011, 01:09 PM   #4
Simplest/cheapest fix, cut the springs or buy new lower springs. You definitely do NOT want to get into change/cutting body mounts.
Old 10-12-2011, 01:17 PM   #5
big_al_71
big_al_71's Avatar
Get two inch lowering springs and the front will be lower. My truck has a 4/6 drop kit right now and the front is exactly two inches lower than the rear.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-12-2011, 01:43 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
I'd spend the 45min doing something free, simple, and very common way before I attempted an uneven body drop, that could take weeks to get right!
cut the springs, my springs are cut and it improved the ride. Cutting the spring does reduce suspension up travel but it also maks the spring stiffer.
a one inch drop spring probably sits higher than a stock spring with 40 years of sag.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-12-2011, 02:10 PM   #7
leddzepp
Moderator
leddzepp's Avatar
cut one full coil out of your front springs. it will give you 2-2.5 inches of drop, its free, it will not alter the ride quality, and can still be perfectly aligned. heating the coils will kill your ride quality.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 10-12-2011, 02:16 PM   #8
YBNORML
YBNORML's Avatar
X2, I totally agree!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-12-2011, 02:51 PM   #9
El Campo
El Campo's Avatar
Hmm ok, good advice. I will most certainly think about this. I had heard that cutting your springs make the ride go bad but if others have not found that to be so then it is indeed an attractive option
Hook em Horns!!!
Old 10-12-2011, 04:49 PM   #10
longbed67
longbed67's Avatar
I would cut the springs first, and if you dont like something after you do that you can always run Schroeder Valved airbags up front with all the brackets for less than $200
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-12-2011, 07:15 PM   #11
YBNORML
YBNORML's Avatar
I have not noticed a difference in ride quality when cutting only 1 full coil. However you do run the possibility of hitting the control arm bumpstops if you cut too much. It all depends on your setup.
On my 2wd 72 blazer I am running a 2-1/2" drop spindle with 1" drop springs. It was not low enough so I cut 1 full coil. It does not ride any different than it did before I cut.
Jason
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
