Old 04-15-2003, 08:16 AM   #1
TC70C10
TC70C10's Avatar
Exhaust Manifold Removal
Anyone had to pull the left(D.side) exhaust manifold out of a S/T-10 Blazer?
The manifold is loose but I can't work it out of the slot. I think they built the truck around it. Not quite sure how you change the plugs on that side.
I don't know whether it would be easier to removing steering column, or drop the exhaust and pull the front drive shaft.(4wd)
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 04-16-2003, 02:33 PM   #2
TC70C10
TC70C10's Avatar
For anyone that cares. I had to remove the steering input shaft from the steering box to pull out the exhaust manifold. It looks to me that you'd have to remove the shaft to change the spark plugs on that side.
I changed 3 plugs, so now I'll have to look at changing the 3 on the passenger side. Doesn't look like very much fun.
Harvest, AL 35749
Old 04-16-2003, 05:55 PM   #3
PHOENIX
So you have an S/T-10 blazer?
What exactly is that, just a little blazer?
Sounds like a pain.
Doesn't anyone know of an s-10 site he and other s-10 owners can hit up?
It seems like alot of s-10 guys come here and get no responses.
There must be a place for these guys!
Good luck!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 04-16-2003, 07:55 PM   #4
1FaastC10
1FaastC10's Avatar
Eddie, yes a S/T 10 BLazer is just an S-10 Blazer. S-series trucks are 2wd, T-series trucks are 4wd. exactly the same relateionship between C/K and R/V trucks.
1FaastC10 is offline   Reply With Quote
