Old 10-12-2011, 03:32 PM   #1
glljr
Intake
quick question I am running a stock 350 with a performer plus cam with performer intake and a holley 600. Would an air gap style intake work well with this combo or should i stick with the performer intake? (The edlebrok performer intake that is on the truck now is about 15 yrs old)
glljr is offline   Reply With Quote
Old 10-12-2011, 03:51 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Intake
If you drive in cooler weather, I dont think you will like the airgap intake(not as nice for warmup time).For the stock combo, I would stick with what you have,as long as its working for you crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-12-2011, 07:17 PM   #3
FLDBRED
Re: Intake
I would stick with the Performer,the Air Gap might give you a slight increase in HP at higher RPM,but you would probably not feel it in normal driving!
FLDBRED is offline   Reply With Quote
