Old 04-15-2003, 08:17 AM   #1
TC70C10
TC70C10's Avatar
Exhaust manifold removal
Anyone had to pull the left(D.side) exhaust manifold out of a newer S/T-10 Blazer? 1995 w/ 4.3L
The manifold is loose but I can't work it out of the slot. I think they built the truck around it. Not quite sure how you change the plugs on that side.
I don't know whether it would be easier to removing steering column, or drop the exhaust and pull the front drive shaft.(4wd)
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 04-16-2003, 02:35 PM   #2
TC70C10
TC70C10's Avatar
For anyone that cares. I had to remove the steering input shaft from the steering box to pull out the exhaust manifold. It looks to me that you'd have to remove the shaft to change the spark plugs on that side.
I changed 3 plugs, so now I'll have to look at changing the 3 on the passenger side. Doesn't look like very much fun.
Harvest, AL 35749
Old 04-16-2003, 03:41 PM   #3
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
That sucks Tim . Good luck with the other side.
See, I care!
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 04-16-2003, 11:28 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The plug can be removed (I am parting out a 2 wheel drive 92 S-10 Blazer) but it is a real PITA.
Old 04-16-2003, 11:31 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I had to jack my uncle's truck up and go in through the wheel well...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-17-2003, 12:02 AM   #6
Longhorn Man
Yeah..I failed to mention that part.
Heck, I do most of them through the fender wells.
