Fuel gauge wiring problem
I accidently pulled out wire from under neath dash. It came from the gas tank fuel sender. Now does it hook directly up to the fuel tank gas gauge or does it go to fuse panel first?
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
![]() Join Date: Nov 2007
Re: Fuel gauge wiring problem
It goes into the 12 pin connector that plugs into the back of the cluster.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
its all about the +6 inches
fuse box... there's a spot labeled for it. A good photo can be found on the electrical forum in the FAQ section.
Thanks Longhorn I'll take a look.....
