Converting from 4wd to 2wd
Can I do this by simply changing out the front cross member? I believe the frame on a 4wd is arched more or something.
Re: Converting from 4wd to 2wd
whole front suspension has to be changed out basicly but yes it can be done
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Is the frame not different?
It would litterally be easier to swap your frame to a 2wd frame.
John 82 Chevy Silverado 350ci/TH350 ![]() |
1/2 ton frame is is a 1/2 ton frame only diff i beleive if its been loaded with 2wd or 4wd running gear from factory same with 3/4 ton frames to
I am looking at buying the crew cab project off 72supercheyenne. The frame he has is a 4wd. I have a 2wd parts truck that I can take everything off of. I believe these frames are different and do not know if it's possible to use the 2wd cross member and a arms in place of the 4wd stuff.
#7 | |
Yes, that is correct. I don't suppose it matters. I have a welder and if it's different I dan cut the frame off and put the 2wd section in it.
Thats a little different, I thought your OP was about a complete truck. Should be relatively easy then, but youll need more than just the front cross member.
