Old 10-12-2011, 05:41 PM   #1
Beat68CST
Beat68CST's Avatar
Been working on my Cummins swap, finally! :D
Two weekends ago, my dad dropped a buddy and I off in Temecula Ca, we bought the truck and drove it home.
This weekend, grandpa came over, a friend of mine and we got to yankin the 12v P-pumped Cummins and 47RH.
NOW!
I'm busy cuttin the main cross member to lower it's overall height so I can get the crank centerline lower in the truck.
I'll post some pictures tonight, most likely around midnight. Should have my crossmember all plated and hopefully atleast tacked up by then!
Beat68CST is offline   Reply With Quote
Old 01-13-2012, 02:45 AM   #2
Beat68CST
Beat68CST's Avatar
Re: Been working on my Cummins swap, finally! :D
Food for thought.
Pretty proud of the trans clearance (:
Old 01-13-2012, 02:50 AM   #3
ColinOpseth
Dude...talk about a beast. That's a cool project.
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 01-13-2012, 03:09 AM   #4
Beat68CST
Beat68CST's Avatar
Thanks buddy, gonna do a 2-1 intake horn since the stock won't fit, also have another turbo and injectors, now I need to build the PoS Moparts trans to handle it.
Old 01-13-2012, 08:01 AM   #5
kamikazekyle05
kamikazekyle05's Avatar
Looks great, what did you use to mount the engine?
kamikazekyle05 is offline   Reply With Quote
Old 01-13-2012, 01:18 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
That's very very cool!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-13-2012, 02:07 PM   #7
black_sheep454
I can't wait to find a good deal on a 6bt and nv4500 for my square. Looks like you've got a good start.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-13-2012, 03:20 PM   #8
Beat68CST
Beat68CST's Avatar
http://www.ballisticfabrication.com/...ng_p_1663.html
I'm using two of these on each side, these things are stocky lil bastards.They have the 5/8 bore, the mounts on the chassis will be similar to the 2nd Gen Dodge pickup. I haven't finished building those and all yet so no pics.
Old 01-18-2012, 09:36 PM   #9
viking427
Can you post a couple pics of how you modified the 2wd crossmember to lower the engine, and the frame area where it interferes with the AC compressor - or does it clear the frame now that the engine is lower ?
Are you using stock 1/2 ton A-arms and ball joints or something beefier ?
Rearend = D60, D70 ? Any plans to box or reinforce the frame ?
viking427 is offline   Reply With Quote
Old 01-26-2012, 01:44 PM   #10
Beat68CST
Beat68CST's Avatar
Yeah I should be able to snap a few pictures, the truck's a 3/4 ton, just using all the stock replacement ball joints and such.
I plan on cuttin a piece of 3/16 plate to put on the inside of each frame rail from right in front of the crossmember to probably the middle of the cab, not sure how far back yet.
Old 01-27-2012, 11:40 AM   #11
Beat68CST
Beat68CST's Avatar
The rearend is an Eaton.
There's some shots for ya, hopefully answers all your questions.
Old 02-23-2012, 01:53 AM   #12
kamikazekyle05
Any updates?
Old 02-24-2012, 01:32 PM   #13
68GenIII
What are your plans for the steering? You planning to use a power rack?
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 05-10-2012, 06:28 PM   #14
Beat68CST
Beat68CST's Avatar
Here's a few more.
Steering will be all the stock Chevy stuff with the stock Saginaw looking PS pump on the Cummins hooked up to the Chevy box.
I worked realllll hard on them motor mounts! Happy those are done...
Old 05-10-2012, 07:03 PM   #15
Gobbles
Gobbles's Avatar
Sick swap, I plan on doing this to my truck too!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 05-10-2012, 07:30 PM   #16
kamikazekyle05
Lookin good, what tranny are you using?
Old 05-10-2012, 07:49 PM   #17
Beat68CST
Beat68CST's Avatar
47RH
Dodge's 4 speed overdrive automatic.
