Old 10-12-2011, 10:03 PM   #1
Wildcats_95
Wildcats_95's Avatar
Cool '64 rear end swap out
Ok, I looked over the FAQ before posting and didn't see this one yet...but I am sure it is there. I am replacing the inline 6 in my 64 C10 with a 350 engine and 700R4 transmission (original I know). Was talking with a guy at the shop today who said I would probably have to replace the rear end. How hard would it be to swap out the original and put in a Ford 9 inch? What measurements do I need to make sure of before proceeding? Thanks in advance, and yes, I know I don't know a lot about this stuff...just learning as I go along.
Wildcats_95 is offline   Reply With Quote
Old 10-12-2011, 11:56 PM   #2
NorthstarGMC
Re: '64 rear end swap out
You'll have to shorten it and get a custom driveshaft.
You'll need to move the mounting plates for the u-bolts and line up the diff angle to the trans.
It can be done, but it's not just a bolt up job. I've read about a lot of people bolting up S-10 rear ends easily. Search the forums for S-10 rear ends.
1963 GMC Wideside powered by a LH2 32v Northstar
NorthstarGMC is offline   Reply With Quote
Old 10-13-2011, 01:02 AM   #3
Captainfab
60-66 Nut
I see absolutely no reason to change the rear end in your truck. What you have is a truck 12 bolt, and as long as it is in good condition, you're not going to tear it up. That same rear end was used up thru '82 in the C10's, and thru '79 in the K10's, behind big blocks as well as 6 cyl's. If the gear ratio is an question, you have a 700R4, so it should be just fine.
If you insist you need a 9 inch, that will require shortening a housing, custom aftermarket axles, welding on trailing arm mounts, fabricating a panhard bar mount, etc. Plus a good bit of money.
Old 10-13-2011, 01:30 AM   #4
blackedoutharley
^^^^ THIS!
I would rather have a worn out 12 bolt before I would ever consider a rear end from an S-10 (of all things).
blackedoutharley is offline   Reply With Quote
Old 10-13-2011, 01:57 AM   #5
NorthstarGMC
How about a 14 bolt posi? Anyone have some 8 lug steelies?
Old 10-13-2011, 07:08 AM   #6
J.Cagle
J.Cagle's Avatar
what rear end does an 84 suburban have? Are they ok to use?
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 10-13-2011, 07:35 AM   #7
brokenspoke
brokenspoke's Avatar
They are wider
brokenspoke is offline   Reply With Quote
Old 10-13-2011, 07:54 AM   #8
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Originally Posted by Wildcats_95 View Post
... Was talking with a guy at the shop today who said I would probably have to replace the rear end...
Just curious: did the guy say why? was he thinking the 6 cylinder rear was weaker than those that came with the V-8s?
Larry
fleetsidelarry is offline   Reply With Quote
Old 10-13-2011, 08:01 PM   #9
Wildcats_95
Thanks all! The guy was saying it would be an issue because the 6 cylinder was weaker than the 350. I posted this because my intention was to just keep the original rear end but thought this guy might know something I didn't. But thanks to you all, I will continue with my original plan. @Captainfab -- I was thinking that going to the 700R4 was a pretty good combination with the existing rear end...thanks for the confirmation.
Really appreciate all the advice...Thank you
Dave
Old 10-14-2011, 12:54 AM   #10
Captainfab
60-66 Nut
An '84 Suburban, assuming it is a 1/2 ton, will have the 8.5" 10 bolt. And yes they are wider....1-1/2" wider than the '63 to early '70 rear ends. The 8.5" 10 bolts are plenty good for a lot of applications. They are stronger than most people give them credit for
Originally Posted by brokenspoke View Post
They are wider
Old 10-14-2011, 04:37 AM   #11
blackedoutharley
The rear ends were the same 12 bolt to 12 bolt regardless of the engine... I would certainly suggest servicing it with fresh oil as a minimum though
Old 10-14-2011, 05:25 AM   #12
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Man this guy is quick!
That's about what I was going to say.
fryer1979 is offline   Reply With Quote
Old 10-14-2011, 09:56 AM   #13
Budman56
Budman56's Avatar
Dave
WILDCATS
I did change the axle and it wasnt too hard to do but there is work to be done, you either have to buy the brackets to weld onto your doner axle or cut the ones off your old alxe. here are some photo's of when I did mine, also I installed a 700r4 trans with the doner alxe from 1990 c20 dana 70 with 373 gears. Captian fab and all the other guys in this forum have most of the info you will need to do the swap if thats what you wind up doing in the end. my swap only took the weekend to complete.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 10-14-2011, 10:15 AM   #14
chevyrestoguy
chevyrestoguy's Avatar
I am in the middle of doing this swap as well, and Budman56 summed it up exactly.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-14-2011, 08:54 PM   #15
Wildcats_95
@Budman -- Thanks for the advice and posting the pics. That is a very nice set up you have there. I think I will stick with the original rear end. I might bug you later to see what you needed to do for the crossmember for the 700R4. Looks like the engine bolts right up to existing engine mounts.
Thanks again all for the help.
