Old 10-12-2011, 11:34 PM   #1
jesse977
jesse977's Avatar
got a new sending unit...gauge still doesnt work
I got my new sending unit today. I hooked it up without the gas tank and the fuel gauge needle still doesnt work. It stays at 1/4 full. What other things should I check?
jesse977 is offline   Reply With Quote
Old 10-13-2011, 03:08 AM   #2
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: got a new sending unit...gauge still doesnt work
Check the integrity of the sending unit's wiring, which means getting under your truck. On both my C-10 and my cousin's truck, the wiring was grounding out on the frame, right below the passenger side door. The clip holding the wire secure to the frame had frayed the wire's insulation and was giving both of us false readings on the gas gauge. A bit of electrical tape solved the problem.
78 Big10 454 is offline   Reply With Quote
Old 10-13-2011, 08:53 AM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Wait so the clip and ground are supposed to be attached to the frame? I glanced at mine for any obvious problems because my gauge isn't working right and I though that it was supposed to be grounded to the tank.....guess that might be my problem.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-13-2011, 09:26 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
Do you have a good ground from the sending unit to the frame
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-13-2011, 10:56 AM   #5
tucsonjwt
Aside from checking the grounds, you could have a bad gauge. I replaced both my sending units and then found out it was my gauge that was bad.
tucsonjwt is offline   Reply With Quote
Old 10-13-2011, 04:03 PM   #6
jesse977
jesse977's Avatar
I use the frame as the ground. Im going to use my angle grinder to clean up where the ground wire bolts to. My gauge cluster seems fine, the other gauges work. I guess ill take it off and inspect that as well.
Old 10-13-2011, 04:49 PM   #7
makman1297
makman1297's Avatar
Mine had a connection problem on the guage, where the printed circuit attaches to the guage. I would tap (smack, hit) the guage and then it would kick on again, kinda annoying.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 10-13-2011, 07:23 PM   #8
Goldfinger
Goldfinger's Avatar
IF it's non of the above it may be the gauge or printed circuit
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-19-2011, 10:24 AM   #9
81Stepper
What did you end up doing?
81Stepper is offline   Reply With Quote
Old 10-19-2011, 09:05 PM   #10
naughty240
Im also in the club of no gas gauge, Ill have to check the ground too.
naughty240 is offline   Reply With Quote
Old 10-19-2011, 10:08 PM   #11
juiceman650
juiceman650's Avatar
Mine just drops down to 1/2 full as I waste gas, but then it won't go lower.
1975 Chevy Cheyenne w/ v8 350 and TH350
Siverado interior
Fleetside bed
aka "The Beast" aka "Cheyerado"
juiceman650 is offline   Reply With Quote
Old 10-20-2011, 01:27 AM   #12
jesse977
jesse977's Avatar
I checked the wires and they seem ok. Im gonna go to the junkyard and get another fuel gauge. If that does not work well then I have no clue what to do next. I was just wondering might a fuse be the problem?
Old 10-20-2011, 01:46 AM   #13
juiceman650
I don't think there's a specific fuse for it, but then again I could be wrong.
Siverado interior
Fleetside bed
Old 10-20-2011, 07:45 AM   #14
tucsonjwt
I would stay away from junkyard fuel gauge unless you can somehow verify that it is in good working condition. A new fuel gauge from Classic Parts is about $50. If you can "borrow" a known good working fuel gauge from another square that is the best option.
Old 10-23-2011, 10:39 AM   #15
naughty240
Maybe you could go Dakota digital w new sending unit. After all it is very dangerous not knowing your fuel level. *helps justify you getting a baller gauge kit*
Old 10-23-2011, 11:31 AM   #16
jdheff1982
Up until recently, I thought my sending unit was bad. Turns out, the gauge needle had been installed wrong.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
