Old 10-13-2011, 06:07 PM   #1
72gmcshorty
72gmcshorty's Avatar
Shaved firewall with heater....
I plan on retaining the original heater box but i don't have one. I was wondering what holes could be covered up on the heater side of the cab?
I've noticed lots of guys cover up the hole for the e-brake and wiring harness. What do you do for the wiring and e-brake?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-13-2011, 09:38 PM   #2
bruin_d
bruin_d's Avatar
Re: Shaved firewall with heater....
I went with Lokar's e-brake setup that mounts with their shifter. Looks/works good. The only wires I have coming through mine is the plug. Everything else is re-routed or removed. You'll be surprised how much unnecessary wires are there from 40 years of retards running new wires all of the time and either not removing the old ones or not realizing they can get power from somewhere close/cleaner.
bruin_d is offline   Reply With Quote
Old 10-13-2011, 09:52 PM   #3
trkfrk
trkfrk's Avatar
I have the original heater box out of my truck if you want it. Not sure if the shipping will cost you more than its worth. PM me if you want it.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 10-14-2011, 03:14 AM   #4
72gmcshorty
Thank you but i'm pretty sure it would be way too costly. Thanks though
1992 Gmc 2wd
Old 10-14-2011, 02:32 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
I'm confused on what you're referring to. Do you mean the e-brake that mounts on the tranny? I looked at the Lokar site, and that's all I saw...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
