Old 10-13-2011, 10:01 PM   #1
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
How to preserve surface rust?
I have a all original 1987 longbed red/white factory paint 350/700r4. The question i have is, it has some surface rust on top of the cab and on the hood, how can i preserve this from happening anymore, and keep the original paint? I want to know if CLR works and do i use a sand paper or? Thanks
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 10-17-2011, 09:32 AM   #2
rayfinseats
Re: How to preserve surface rust?
Sand down the rust. Use "Rust Mort" and repaint the area. Be sure to use rubber gloves , eye protection, resperator.
rayfinseats is offline   Reply With Quote
Old 10-17-2011, 12:27 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
CLR works miracles. Dont touch it with sand paper if you are trying to save any OE paint like you said in the original post.
--Josh
Old 10-17-2011, 07:38 PM   #4
oldblue72c10
thanks ill try the clr
