10-13-2011, 10:36 PM | #1 |
progress
Made some progress, got it sanded with 180, prime tomorrow. 1st attempt at painting in 30 + years.
10-13-2011, 11:45 PM | #2 |
Re: progress
woo hoo!
congrats! -W |
10-14-2011, 12:00 AM | #3 |
Rollin' Old Skool
Re: progress
cool! good luck...what color?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-14-2011, 12:33 AM | #4 |
Re: progress
Just stock single stage blue with white top. Body work is going to be far from perfect, just need some color as it sits outside.
10-15-2011, 04:45 PM | #5 |
Re: progress
Looks great! I started painting again after about 25 and it comes back to you fast, plus these urethane paints are great to use. Good luck
Hal |
10-15-2011, 08:51 PM | #6 |
Re: progress
I got it in primer today, using tp tools turbine system, its all I have. Most panels look good, smooth execpt the hood. About 20 minutes after the last coat it started looking like it got dirt in it. I used ppg 312 urathane surfacer and slow reducer mixed 4 to 1 to 1, waited 30 minutes between coats. Put on 3 coats. TP tools said to use reducer in the primer as the turbine heats the air. Used a 1.8 tip. This was shot over 5 year old primer that i 180 gritted. What went wrong ,solvent pop? moisture? Thanks.
10-15-2011, 09:13 PM | #7 | |
Re: progress
10-15-2011, 10:15 PM | #8 |
Re: progress
Every thing was dry, the turbine heats the air, so no water or oil in the paint. I'm going to use 320 wet to see if it sands out, I have just enough primer left to do the hood and maybe the tailgate, I had it in the garage and forgot all about it, it didn't get a single coat.
