Correct headlight for 69 C10
I purchased a Sylvania H6024 from ORiley for my 69 C10. The lugs on the mounting bracket don't match the lugs on the headlight unless I turn the head light 90 degrees and then the vertical lines on the headlight, are no longer vertical. I don't hink this is correct. Any help would be appreciated.
Posted via Mobile Device |
![]() Join Date: Jul 2010
Re: Correct headlight for 69 C10
You can check out my build thread where I show my Sylvanias installed. I used 6024ST. Maybe your buckets are installed on the wrong sides?
Board Member #87725 My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=813848 |
That was it,. Buckets on the wrong side. Thanks omodified. Must have been a senior moment on my part
