Anyone else using an Explorer frame?
I bought my 49 without a frame with plans to put it on a modern chassis. Got to looking at options and decided that other than being a Ford, the explorer frame was the best option. Get 4 wheel disc brakes, strong 8.8" rear, R&P steering tucked out of the way and easy to adjust torsion bar front suspension. I have the cab mounted and the all the mounts for front sheet metal and bumper done. Still a lot to do but looks good so far. Just wondering if anyone else has done this. This picture is prior to trimming the excess frame off that is sticking out from the fenders. I'll post some more pictures later if anyone is interested.
Re: Anyone else using an Explorer frame?
We definitely need more pics. Is that the stock ride height?
Jeff |
#3 | |
Also had to add a 4" section to the frame to get wheel base from 112" to 116. |
You need to do a build thread. I was thinking of this but did the Dakota.
![]() Join Date: Apr 2009
X2 build thread. Nice work. Youve got it this far i think youll figure it out. Never heard of an explorer swap...cool.
Posted via Mobile Device |
That looks interesting. The trouble in this area would be finding a two wheel drive Explorer. I doubt if any of the local dealers have ever sold one. Or is it a four wheel drive minus the front axle and drive pieces?
The frames are the same. My 2wd frame had all the mounting tabs for 4wd parts. Front hubs are different but can use 4wd ones. They just have place for splined axle to fit in.
[QUOTE=meter swinger;4954293]X2 build thread. Nice work. Youve got it this far i think youll figure it out. Never heard of an explorer swap...cool.
Posted via Mobile Device[/QUOT I started a build thread here http://67-72chevytrucks.com/vboard/s...d.php?t=489061 It will take a little while to catch up to where I am. Also just discovered that I deleted some picture that I did not mean to. ughhhhhh! |
a friend of mine did a complete swap with a wrecked ford lightning, motor and complete drive train. its bad ass
![]() Join Date: Jul 2010
that is thinking outside tha box..
you could have this moved to tha build section
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
