10-14-2011, 10:13 AM | #1 |
removing br. on donor rearend?
Have a ford 9 in to go in my truck but was wondering if a plasma cutter will take them off nice with little grinding to do.There is 6 brackets and a couple are almost 1/4 in thick.
10-14-2011, 10:53 AM | #2 |
Re: removing br. on donor rearend?
Plasma or a torch; both will get it done. For some brackets, you might be better off using a cut-off wheel too.
10-14-2011, 04:20 PM | #3 |
thanks,I got most off with a grinder but 2 brackets are kinda flush with the rear and I don,t want to dig to deep.I,ve never seen a plasma work so I don,t know how accurate they are
10-14-2011, 05:38 PM | #4 |
If the angles are awkward, they dig deep or leave material behind. They work best when square w/the material being cut.
10-14-2011, 08:20 PM | #5 |
Either a torch or plasma in a knowledgeable hands can make a good cut. It's the best bet
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
